It is currently Sat Jul 19, 2025 7:38 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Nov 01, 2007 12:47 pm
This space for rent
None at all, nor would I have expected it. The only suspension position in which contact between caliper and caster arm is possible is almost fully extended, with the wheel's leading edge pointing inwards with two thirds lock.
Under pretty much any driving circumstance, those two conditions are basically mutually exclusive. With the steering in that position, the suspension on that side will be compressed, not extended.
Unless of course, you get big air mid corner in which case there's other, more Armco-ish things to contend with :lol:
Oh, and btw.. there's no marks on the calipers either, which lends credence to the theory.
PostPosted: Thu Nov 01, 2007 1:59 pm
Well I'm sold. :lol:
I guess I need to place that order then.
2008 Prado GXL
PostPosted: Sat Nov 03, 2007 6:43 pm
would the mini spare disc would fit into 12x5 superlites? the diameter of the wheel are good but would the offset be deep enough?
PostPosted: Sat Nov 03, 2007 6:51 pm
This space for rent
Easily. If they fit under 10" Contessa's, there should be no problem with pretty much any 12" rim.
