Hanra wrote:
Ok so its in and out the free play. Check the bolt at the spline end of the colum. Confirm its tight. If it is, then its the pinion itself moving up and down inside the rack.....
If so, drop the front subframe out of the car about 3-4 inches and remove the entire steering rack and get it reco'd, and check the condition of the splines in the lower part of the colum.
It's dangerous if spline is worn out, you can go straight ahead on corners. Eh, 9YaYaH...its 9YaTaH Doc
...you make me sound like an old cricketer
Yeah or worst of all...you might not go straight ahead where you might at least have had some chance of getting on the brakes.
When a Mini steering becomes unnconnected you have a big chance of the wheels flopping to full lock depending on the camber of road, previous wheel angle etc.
Hanra...no offence, but checking the tightness of the pinch bolt whilst good practice completely ignores the possibility that it is almost worn through and no longer clamping the pinion. If the splines on the pinion are damaged or missing
then it is also a little academic to be checking the tightness of the pinchbolt.
If the pinion has major problems with the rack then it needs to be fixed ASAP because it can kill you.
Rant nearly over
To reiterate....the reason we need to be careful here is that there are plenty of youngsters and others out there in Mini land who have no idea just how important this area of a Mini is and how hard it can bite if not quckly attended to....
Both the Doc and myself have walked away (eventually!!) from big shunts caused by failures in this weak area of design in the Mini. In my case, I kept driving a car with about 1-2 inches of freeplay in the steering wheel whilst I waited for a replacement rack to be delivered. Not an excessive amount of freeplay in an old steering system...but it jumped up and bit me
(and please, nobody rabbit on about how Mini racks were good enough to be used in Ferrari 308s after lengthening etc....)
