It is currently Wed Jul 23, 2025 12:32 pm
PostPosted: Fri Nov 16, 2007 11:34 am
Basic question probably.
Scenario. 1970 panel van. Standard drums. Converting to 7.5" Cooper S brakes with no booster (probably no booster, I love how my unboosted 8.4" discs feel at my foot on the LS).
I will be putting in a new master cylinder no matter what, but is there a difference between disc and drum master cylinders?
PostPosted: Fri Nov 16, 2007 11:36 am
nah... not if it's a new MC
PostPosted: Fri Nov 16, 2007 11:40 am
This space for rent
I have the Oz-style large circular plastic reservoir type master on my K, which I recently converted from drums to discs. I was expecting to have to change the MC, but it turns out that type is 0.7" diameter and is already suitable.
I believe if the non-return valve was operational it'd need to be removed, but it was stuffed anyway so I got away without touching it 8)
PostPosted: Fri Nov 16, 2007 1:19 pm
If running with no servo, the 0.7" bore is the one to use.
Even a Deluxe tin tank one would do, but you need to add some fluid volume to let it drop as pads wear. Those plastic extensions work good- but need an O-ring so they seal. :wink:
<edit> the new plastic reservoir ones are good, you can see fluid level.
PostPosted: Fri Nov 16, 2007 2:21 pm
I'll be buying a new plastic tank one.
PostPosted: Fri Nov 16, 2007 4:19 pm
ausmini mod
ausmini mod
I put one of the new clutch ones on mine (its a new plastic one) and its great... can see fluid level and the cap screws on nice and tight.
I used the extensions on my tin ones and snapped off the thread :( I didnt use the rubber O ring and it leaked... if you get the extensions they are good, just make sure you use the O ring as Doc says.
Pete
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 87 guests
