It is currently Sun Jul 27, 2025 4:01 am
PostPosted: Mon Dec 24, 2007 12:46 pm
In the process of of stripping the deluxe, and starting to research for an engine rebuild, got a little confused while checking out the casting number of the head...(hoping it was going to be a 12G202 :D ) I found 2 stampings and one casting number, the casting number is "ECAM4004", on the top near the thermostat housing I found a stamping of "/3C6" and on the opposite end I found stamping of "UN969"
Now I know the head had been done for unleaded, but it appears the head may have been replaced completely...the only reference I found similiar to the casting number is CAM4180 which is a casting number from a 998 Mini - A+ (1980-on) and lead free
Would anyone be able help id this head for me so I can find the specs on it...
Jason
PostPosted: Mon Dec 24, 2007 1:01 pm
To find the number to ID the head you need to take the rocker cover off and it is cast into the head under the rockers.
Pete
PostPosted: Mon Dec 24, 2007 1:02 pm
Thats where I got the ECAM4004 Pete... :)
PostPosted: Mon Dec 24, 2007 1:04 pm
It's a late 998 head. :wink:
NOT a 202.
PostPosted: Mon Dec 24, 2007 2:17 pm
Thanks Doc, late as in the A series, A+ late?
I know it isnt a 202, I just had fingers crossed prior to removing rocker cover to check the casting number, as you never know til you look :D :P
PostPosted: Mon Dec 24, 2007 2:32 pm
does it have 4 smog ports on front, if so it's from a late Oz Clubby 998.
PostPosted: Mon Dec 24, 2007 3:29 pm
Im guessing that would be the 4 ports/stud hole looking areas across the front that have been filled and ground back....if so, yes :)
PostPosted: Mon Dec 24, 2007 4:53 pm
ausmini mod
ausmini mod
Yep, ECAM4004 is late model 998 Smog head. Mine had that with the charcoal canister, etc.
They can be worked exactly like a 12G202 can...
Pete
PostPosted: Mon Dec 24, 2007 6:54 pm
cool...thanks guys :)
Users browsing this forum: No registered users and 112 guests
