It is currently Thu Aug 14, 2025 7:31 pm
 Post subject: Metro disc uprights
PostPosted: Mon Feb 18, 2008 10:51 pm
Hi guys,
I've got myself a set of metro 4 pot calipers + hubs, the works and would like to fit ALL of it into the mini.
yes, i know its easy to fit them into standard mini uprights ( which I have by the way).. but I am finishing off a starlet engine conversion and am specifically keeping the metro hubs to get more king-pin angle.
plus.. the standard discs would fetch a better price with the standard hubs :D
The tapers on the metro ball joints are all messed up, i.e. they are bigger than original. :?
Has anyone had this issue before?
What has everyone done with this?
I am going to take them off and get the tapers re-machined to be idential to the original mini ball joint taper.
Would this be alright??
Cheers :)
pubs
PostPosted: Mon Feb 18, 2008 11:01 pm
there are 2 types of metro ball joints, the older one, pre '85 IIRC, fits. the later one won't.
just get the correct ball joints
Rover 214 atm ....
PostPosted: Tue Feb 19, 2008 12:25 am
Yes, just order a set of "MK1" metro ball joints, they have the same taper on the pins as mini
Sounds like you have MK2 ball joints at the moment
easy-peasy
PostPosted: Tue Feb 19, 2008 9:37 am
Thanks for the info guys
Can you recommend me a place in Australia ( in SA preferrably) where I can buy 4 of these?.. how much would they be?
My neighbour works at a machine shop so I might get him to turn them anyway and see how it goes.. will sae a bit of money anyhow..
Cheers guys
pubs
PostPosted: Tue Feb 19, 2008 9:39 am
I wouldn't get them made, better off buying a set.
Buy good ones, cheaper balljoints in the UK have been known to shear.
PostPosted: Tue Feb 19, 2008 10:29 am
www.karcraft.com.au stocks them, p/no is GSJ268.
PostPosted: Tue Feb 19, 2008 5:54 pm
ive just got to put a post in here so i can find this thread again, :roll:
PostPosted: Wed Feb 20, 2008 10:04 am
pubs
I got mine through morris mania
4efte powered Clubman
supercharged 998 race car
Users browsing this forum: AWOODY, Bing [Bot] and 272 guests
