It is currently Sun Jul 20, 2025 4:30 am
PostPosted: Thu Feb 21, 2008 10:36 pm
When I was a kid I used to help out at the local machinery museum restoring tractors
with some of the old farmers of the district and was amazed at what a little CRC would free.
From rusted levers to seized pistons that had been stuck for decades!
Good gear.
Keep at it lilmatti. Skin those knuckles!!!
Image Image
PostPosted: Thu Feb 21, 2008 10:39 pm
Does anyone remember Penatrine. it was in a non pressurized can. amazing!
I live with fear everyday. but sometimes she lets me race.
PostPosted: Fri Feb 22, 2008 5:53 am
Yep it's spelt Penetrene, I used it in the 60s, it's good stuff if you find it.
PostPosted: Fri Feb 22, 2008 6:26 am
i'm 24 and i borrowed/stole a can of crc from my mother because it worked better than the wd40 i was using, now i know how good it is, it's only used for special occasions... 8) , thanks mum...
Daniel the concreter (for now)
1974 mini 1100, fully sick rims, disk brakes, new paint, air conditioning, cruise control,v-tech... wishful thinking
PostPosted: Fri Feb 22, 2008 6:47 am
I dont know that they still make it Doc, but it was excellent.
PostPosted: Fri Feb 22, 2008 11:13 am
what you need you get the door hinges off is a sidchrome "microtuff" ratchet. the head on these things are tiny and the teeth on the ratchet are very small and fine. (72 teeth in the head as oppose to the standard 36) this means only a small rotation of the head gets results whilst the small head fits in the corners up under the guards. i got one a few years ago in a small socket set and it is the best set of tools i have ever purchased. for work on a mini it is perfect. go get youself a set. you wont be dissapointed. 80 bucks very well spent.
PostPosted: Sat Feb 23, 2008 11:05 am
after about a day and a half of trying i finally removed those damn hinges, used HEAPS OF WD40, a size 11 socket nut, and instead of using a ratchet i used a alan key to turn the nut.
PostPosted: Sat Feb 23, 2008 11:15 am
Well done , most things on mini's aren't as difficult as non mini people will tell you they are , they just need a bit of perserverence and patience .
PostPosted: Sat Feb 23, 2008 11:21 am
just a question what size nut or screw would you need to put them back on as the ones i took off have had it.
PostPosted: Sat Feb 23, 2008 4:11 pm
The threads are 1/4" UNF, nut size is 7/16" A/F (11mm is close enough that it fits OK).
