It is currently Mon Jul 21, 2025 4:35 am
 Post subject: Clear Lenses
PostPosted: Wed Feb 27, 2008 2:35 pm
Mine actually have coloured leds, so they do show the right colour, and when you do buy these lenses they also come with red reflectors.But i chose not to use them.
Steve
Classic Not Plastic
PostPosted: Wed Feb 27, 2008 4:34 pm
It is the lack of reflectors that make them illegal.
How would you feel if someone runs up the bum of your parked car on a foggy night due to the lack of reflectors? :?
PostPosted: Wed Feb 27, 2008 5:06 pm
I guess it depends on what you use your car for. I don't use my car at night.
Steve
Classic Not Plastic
PostPosted: Wed Feb 27, 2008 6:43 pm
As promised, here's the pic. Bottom half is stock rover, the kit is just the top half and some coloured globes.
:D
PostPosted: Wed Feb 27, 2008 6:52 pm
Where??
PostPosted: Wed Feb 27, 2008 7:02 pm
Right there! :lol:
PostPosted: Fri Mar 07, 2008 4:55 pm
That does look good on a white car just makes me sad I cant have the clear light cos my car doesnt have the setup for reverse light so they wont work properly if I do put them on..... :cry: (found that out after I asked the question)
Size DOES Matter!!!
 Post subject: Clear light
PostPosted: Fri Mar 07, 2008 6:11 pm
You can put these tailights in, just leave the reverse lights unpluged.
Steve
Classic Not Plastic
PostPosted: Fri Mar 07, 2008 6:48 pm
Die Die Die!!
a reverse gear sensor from an a+ box would fit wouldnt it ?
PostPosted: Fri Mar 07, 2008 7:12 pm
All Leyland Minis had reversing lights. So there should be no problem getting them to work.
PostPosted: Fri Mar 07, 2008 7:16 pm
They do look mighty good Harley!
PostPosted: Mon Mar 10, 2008 6:53 am
yea them the ones i have - mabey leds would put out a more red light - as mine is really pink with the bulbs that were supplied,
i put the bases in my mini that didnt have reverse lights - run 2 wires from the switch, one to power one to earth and i have to grind 2 small notches in the mounting part in the light recess as one of the bolts is in a slightly different position
backyard performance............. Aint it the best
 Post subject: Illegal tail lights.
PostPosted: Tue Mar 11, 2008 6:22 am
With these crystal tail lights the only reason why they do not comply with ADR because they have not got a rear facing reflector. If you fit a small red reflector on each side of the car you should get around that. Hella make many different bolt on and stick on Red reflectors. Keep the boys in blue happy !
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 85 guests
