It is currently Sun Jul 20, 2025 8:10 am
PostPosted: Wed Feb 27, 2008 7:08 pm
does anyone have a wiring diagram for a fuel injected mini they could email/post to me? I just bought a disk from the UK but it only covers MPI mini's. If anyone needs a MPI mini workshop manual I have a spare...
Noli Illegitimi Carborundum
PostPosted: Wed Feb 27, 2008 7:19 pm
1 or 2 ecu connectors?
i have one of the 2 connector model, its the older one
some special section? or all pages?
Rover 214 atm ....
PostPosted: Wed Feb 27, 2008 7:22 pm
two connector model KLAS, I could really use all of it, I have about 70% worked out just from looking at it but the other 30% is a little trickier...
PostPosted: Wed Feb 27, 2008 7:24 pm
sorry all the diagram related to the fuel injection setup
PostPosted: Wed Feb 27, 2008 7:25 pm
ok, give me your email adress and how big attachments can be and i send you what ever fits your mailbox :wink:
Rover 214 atm ....
PostPosted: Wed Feb 27, 2008 8:42 pm
Benoz, I've got a Haynes manual.
I can photocopy these for you if Klas's soft copy doesn't work out.
Can I ask what you're doing with your SPI?
PostPosted: Wed Feb 27, 2008 9:14 pm
I am installing fuel injection to the 1275 A+ that I am going to fit to my sunshine, I have Klas's email and I am very grateful but a hard copy would be easier to follow and It would be great to get a photocopy if you don't mind! :)
PostPosted: Wed Feb 27, 2008 9:36 pm
No sweat. Just PM me with your address and I'll send it.
PostPosted: Sun Apr 06, 2008 11:26 am
Cough Cough. If someone could please see fit to PM this to me I would be most grateful.
2008 Prado GXL
PostPosted: Sun Apr 06, 2008 11:31 am
I've now got one. Thanks.
2008 Prado GXL
PostPosted: Sun Apr 06, 2008 12:09 pm
Nope, not the one I wanted. I've got a schematic for a 1997 Japan Spi, which appears to be differnet to a 1994 one. Can anyone please tell me off the coil where the Yellow wire goes to?? There are 3 wires currently:
Brown-Pink wire is power (connecrted to the +ve side of the coil, and the other 2 connected to the -ve.
A Yellow wire and a White-Black wire... Where do these go?
Thanks.
2008 Prado GXL
PostPosted: Sun Apr 06, 2008 12:11 pm
Thanks.
If you have air-con the yellow goes to the relay for the fan on the back of the condenser.
Cheers Pete
PostPosted: Sun Apr 06, 2008 12:15 pm
Are you sure?? As when I turn the ignition off it is running ~ 7volts :? . Doesn't seem quite right.
2008 Prado GXL
PostPosted: Sun Apr 06, 2008 1:32 pm
Must be for something else then, sorry. The yellow on my coil is for that but mine is not injected. Best thing to do is to ring steve at brickworx, he is sure to know.
Cheers Pete
PostPosted: Sun Apr 06, 2008 5:35 pm
the yellow is a power to the coil whilst cranking.
only on the carby models... if it is part of the loom.
if it is an extra wire it is normally a/c, but it easy to hook it up wrong inside the car
Miniworx Centre 0883741299
Online BMW Mini Shop
