It is currently Mon Jul 21, 2025 8:42 am
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 24  Next
PostPosted: Tue Mar 11, 2008 12:17 pm
Hey hallsey, glad to see the website was of assistance, it seems it gets around. Also if you don't mind which engineer have you been speaking to?
Matt
PostPosted: Tue Mar 11, 2008 4:14 pm
G'day minstar, Andrew enkelman in braeside vic . I'm guessing
someone got there before me ,had done their research and downloaded info from your site,so when i spoke to him he already had a good idea of what i was on about, with out your input it would have been 100 times harder so cheers for that
cheers Hallsey
PostPosted: Wed Mar 19, 2008 7:34 pm
Hey guys need some help
has anyone sourced a wiring loom or documented what they have done.
cheers Hallsey
PostPosted: Wed Mar 19, 2008 7:44 pm
Forum Graffiti
Aaahh.. I had a pdf of all the looms here somewhere.. can't find it! :evil:
PostPosted: Wed Mar 19, 2008 8:18 pm
try this it is what I used just have to blow them up a little and stick it together
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Mar 21, 2008 5:26 pm
cheers Hallsey
Hi Hallsey,
I have all the wiring diagrams scanned and in soft copy format.
PM me if you want a copy!
Tricky
PostPosted: Tue Jul 08, 2008 7:43 pm
Time for a small update,most of this stuff you've seen on the other builds
but i suppose it shows the progress.
I have started some of the wiring,but it's a slow fiddly job. (Thanks Tricky and 92)
The holes for the two harnesses
Just one of the bonnet
I started to fit the alternator and was finding it difficult to hold,line up etc
on my own so cut out the gaurd for ease of access
I made this bracket up for the alternator but have since changed it
I also got part of my remote oil filter kit
PostPosted: Tue Jul 08, 2008 8:35 pm
geez your gunna havefun with the gaurd? how are you going to put it back in? just weld in a new one or the weld the peice you cut out
looking good hallsey keep up the good work
Mearcat wrote:
PostPosted: Tue Jul 08, 2008 10:34 pm
The yellow car is just a dummy - the 'real' machine is red and ready for the donor once all the fab work is complete.
Good work Halsey, and keep us posted.
PostPosted: Wed Jul 09, 2008 8:39 pm
I know the yellow clubby is a mock up car but that is painful to see that done to a mini :( honestly how bad is that mini :?:
PostPosted: Wed Jul 09, 2008 8:46 pm
Me ol mate Tricky's right on the money there dbr11k,old yella is just the crappa drill, cut , grid and drill a hole in the wrong spot and say "woops oh well' instead of aaaaahhhhhh ive driiled a hole in the wrong spot on my
baby.
Simply Red is the car everything will be going into once i've done as much as i possibly can
cheers Hallsey
PostPosted: Wed Jul 09, 2008 8:51 pm
To far gone for me
cheers Hallsey
PostPosted: Wed Jul 09, 2008 9:42 pm
I know the yellow clubby is a mock up car but that is painful to see that done to a mini honestly how bad is that mini
na i reckon it looks good "puttin speed holes in ma car, makes it go faster"
it all makes sense now :shock: :)
i remember now its just the nets to slow to look back through the pics :roll:
p.s simply red is a good name :P
Mearcat wrote:
PostPosted: Thu Jul 10, 2008 12:00 pm
"Simply Red" - I love it!!
PostPosted: Fri Jul 11, 2008 2:20 am
Hi Hallsey
Where did you ordered your brake's kit from?
How much it cost you?
Thanks
OJ
