It is currently Fri Jun 20, 2025 6:13 am
PostPosted: Tue Mar 11, 2008 11:02 am
Can this be done? I know about the mods to the block for Auto to manual conversion, as per the good Docs sticky; but are small journal 1100S cranks narrow across the centre main like an S crank?
Will I need to thin the thrusts ? :?
PS I did a basic topic search, but did not find an answer to this one! :oops:
Sir Alec! we are not worthy!
PostPosted: Tue Mar 11, 2008 12:46 pm
Hi Graham,
I am not 100% sure but i am sure that the large journal crank from 1100 "S" is the same as the small journal 1100 "S" crank.
but I could be wrong.
100% Pure A Series Turbo
PostPosted: Tue Mar 11, 2008 1:04 pm
Graham, it drops straight in with std thrusts. Mains on small and large J cranks are the same.
You only need thicker thrusts if putting non-S crank into an S block, or thinner thrusts if putting a S crank into any 1275 non-S block (like my 1360).
PostPosted: Tue Mar 11, 2008 7:53 pm
Ah good! Thanks Grant and Doc. my posts been on half the day waitng for someone "in the know" excellent!
Just trying to help out supercooper with a big block build!
Fancy doing a block conversion for us Kev?
PM me with the $ damage or equivalent in slabs! :lol:
PostPosted: Tue Mar 11, 2008 8:32 pm
PMs sent.
Good to see another 1275 auto block being resurrected as a manual. :wink:
PostPosted: Wed Mar 12, 2008 8:03 am
Animal the Nb that Matt68 now owns has an auto block. I went through about manual 5 blocks to find a block suitable for 020 bore.
PostPosted: Sat Mar 15, 2008 8:36 am
I have a good std bore 1275 auto block here if anybody needs one. Would clean up at +.020" no problem. :wink:
PostPosted: Sat Mar 15, 2008 3:45 pm
I have an auto gearbox to stick under it. :lol:
PostPosted: Sat Mar 15, 2008 7:43 pm
.... but, why would you bother.... :lol:
They suck too much HP.
PostPosted: Sat Mar 15, 2008 8:09 pm
yeah i have a friend who owns a boat that needs a good anchor :-)
