It is currently Fri Jul 18, 2025 2:01 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Apr 09, 2008 9:32 am
A Spridget race guy in US has had 10 of these heads cast and machined.
I saw one at GR's recently, it is Mini Porn!! :shock:
The word was no more would be made, but a thread on MM forum indicates there may be another 10 coming, maybe not..
anyhow... enjoy. :P
The MM forum thread is here- http://www.minimania.com/web/threadid/9 ... thread.cfm
PostPosted: Wed Apr 09, 2008 9:55 am
Wow :shock: :D
What are they worth :shock:
PostPosted: Wed Apr 09, 2008 10:05 am
Forum Graffiti
Lots :wink:
There was a big discussion on turbominis about them ---
http://turbominis.co.uk/forums/index.ph ... tid=186425
PostPosted: Wed Apr 09, 2008 10:36 am
Milatsmadmini
Works out to be around £950.00 + shipping/taxes
:shock:
PostPosted: Wed Apr 09, 2008 11:11 am
:shock:
That's not bad, considering an Elder 8 port will cost you near $4K installed and running.
Don't forget the Weslake head needs manifolds, valves, springs etc added though, on an Elder they are included.
PostPosted: Wed Apr 09, 2008 11:19 am
What's better the Elder or the Weslake?
PostPosted: Wed Apr 09, 2008 11:25 am
Weslake, GR says. Inlet ports are far better than any other 7 or 8 port.
The old iron Weslakes were great back in the 60s, but they used to crack.
Ivan Glasby has one of those on his race car.
PostPosted: Wed Apr 09, 2008 11:56 am
I ordered 2 of these heads allready & am waiting for the 2nd batch from Rodger :-)
PostPosted: Wed Apr 09, 2008 12:04 pm
Give Ash some flowers Nick .
Those are beautiful looking heads! I wish I could afford one.
 Post subject: mm1275
PostPosted: Wed Apr 09, 2008 3:00 pm
Man i wish i had the scratch
*Reasonable pricing
*I come to you..
Jay: 0431404607
 Post subject: 8 port
PostPosted: Wed Apr 09, 2008 8:05 pm
doh !!!!!!!!!!!!!!!!!!
the secret is out,will have one in the flesh at minishow 2008 at showgrounds for all to see in victoria.
i agree with the doc it is pure porn,hope roger does some more (im pretty sure he will)
cheers josh
PostPosted: Wed Apr 09, 2008 9:48 pm
Is this because of the angle of the port directly behind the inlet valve? In the Vizard book he talks about boring holes down through the top of a standard 5 port head which would end up with a similar design. I've heard of this being done with other heads but I've never seen a mini one done, and I can't work out where you could do this on a 5 port, as eveything seems to be in the way.
Member VMCI #19
PostPosted: Wed Apr 09, 2008 10:46 pm
You need to see the ports in these to appreciate what Graham means. The air entry to the inlet valve throat is magic.
And Vizard was just talking about 2 siamesed ports, where this has 4.
PostPosted: Wed Apr 09, 2008 10:54 pm
Inlet port reminds me of the Alfa twin cam. Without valves you can see right through the inlet, chamber and exhaust ports.
Very nice indeed.
PostPosted: Thu Apr 10, 2008 6:55 am
I've seen that done with varying results on UK cortina's (one looked good but was seriously let down by the guys engineering skills - body steel silastic'ed over the old ports does not make an effective seal :lol: ) and wondered if it was possible with a mini head but like you couldn't see how it could be done with everythi9ng in the road .
