The Bash is not a race or a rally and speed is not important. What really matters is that everyone has an enjoyable time travelling in parts of Australia they would not otherwise see, at the same time raising money for special needs children.
The Bash was originated by businessman, explorer and philanthropist Dick Smith in June 1985 when he organised a group of people to travel from Sydney to Bourke in Far West New South Wales, and from there to Burketown in Northern Queensland.
Dick wanted to take a few mates for a drive in the outback in old cars and at the same time raise money for charity. He charged everyone to enter, and entrants were able to bribe the officials or be fined.
That first event raised $250,000 for Variety and was known as the Bourke to Burketown Bash.
The annual Variety Bash is Australia's most successful charity motoring event. It is the focal point of fund raising efforts by many hundreds of supporters of Variety, with the money raised helping ill, special needs and disadvantaged children.
What is a Bash Car?
You will need a reliable, well-built vehicle, which will survive the trip and be noticed so that your sponsors receive some benefit.
The transmission, engine and engine ancillaries must be as originally specified for the vehicle. Fuel is always available, but it is advised to carry a jerry can as sometimes it is a long way between stops.
Modifications to the body shape are permitted where such modifications are designed to enhance the appearance of the vehicle for sponsorship purposes or for fun! Modifications to the brakes, suspension & fuel tanks are allowed for safety but no improvements for extra speed or performance modifications.
Attention-grabbing and unusual decorations make for a great Bash car… the stranger the better
First registered before June 1970.
Current registration plus third party property insurance.
Attention-grabbing and unusual decoration…. The stranger the better!
Modifications are allowed for safety but no improvements for extra speed.
for fun!
The engine, transmission and engine ancillaries must be as originally specified
for the vehicle. Modifications to brakes, suspension and fuel tanks are permitted.
Vehicle preparation costs are not to come from your fundraising money. These
are your own expenses.
Two-wheel drive vehicles only. No charabancs, omnibuses, motorbikes or
motorised wheelbarrows!
Be Prepared
As many Bash vehicles are rescued from farm sheds, out of a paddock or underneath
layers of dust and sundry spare parts in workshop corners, it is advisable to pay
attention to some important areas when preparing for a Bash.
1. Lubrication and Cooling – both systems should be drained, flushed and
generally cleaned out. For engines that have been stationary for some time, this
is a MUST. Don't forget the transmission, too!
2. Engine and transmission mountings – check for tears, perished, worn or oil
damaged. (Body mountings if applicable).
Vehicle Requirements
-2-
3. Drive shafts - check the universals, yokes, centre bearings and their mountings
if applicable.
4. Protect exposed clutch and brake mechanisms
5. Suspensions – check the cross members for cracks and worn/perished
mounting rubber joints, links, pins and bushes etc., shock absorbers, springs,
shackles, leaves and centre bolts.
6. Brakes – check the linings, hoses, metal brake lines and their securing, wheel
and master cylinders.
7. Wheel/Tyres – check for wheel cracks and seek out a good “off road” type of
tyre. Go to a tyre retailer and seek his advice, explaining you will be doing a lot of
dirt driving on mixed, country road conditions.
8. Wheel/axle bearings – check seals, clean, inspect repack/grease.
9. Engine – tune and waterproof the ignition.
10. Wiper blades – replace.
Essential Equipment
The items listed below should be carried in your vehicle as a minimum requirement.
These items will be checked at scrutineering.
Fire Extinguisher
First Aid Kit
Two spare wheels/tyres, mounted and inflated (one can be carried on the Bash
baggage truck)
Towing Rope, preferably a "snatchem strap". Wire cables are NOT acceptable
40 Channel UHF CB radio in working order
Roof mounted Flashing amber light with rear roof mounted, downward facing
reversing amber light
Tow ball or hook (front and rear – see further information below under Tow Balls)
20 Litres of fuel in approved containers plus funnel or syphon hose
10 Litres of water, suitable for drinking
-3-
5 Litres of engine oil
5 Litres of auto-transmission oil (if applicable)
Jumper leads (automatic vehicles included)
500mls of brake fluid
One can of WD40 or equivalent
Jack and jacking plate for soft ground plus wheel brace
Fan belt
Spark plugs, plug spanner and points
Radiator hoses
Fuel hoses
Fuses
Heavy duty torch
One roll of racing tape, small roll of tie wire
Basic tool kit: screwdriver, multigrips, spanners etc.
Water pump, fuel pump, fuel filters (desirable but not essential)
_________________ Mini, its in my blood........
