It is currently Sun Jul 20, 2025 5:54 pm
 Post subject: Sticking it in....
PostPosted: Sun Apr 27, 2008 1:06 pm
Hi all
Removal threads are all over the place but I basically cut the last shell from this engine with an angle grinder. So I have no expeirence.
I have a engine crane and my motor is complete, the front end and hubs etc are complete in the car.
I have a rod change box that dosent have the selector assy attached to it.
I am aware off the issue with the engine mounts.
Basically do I just stick it in and guide the joints into the pots?
So I am basically asking for tips
any help will be appreciated
thanks everyone
blokeinamoke wrote:
PostPosted: Sun Apr 27, 2008 1:09 pm
Basically just stick it in , will be easier if you make the lifter plat that's described in the how to's so the engine tilts back a bit and also pop the top ball joints and steering tie rod ends so the driveshafts sit out of the way until you're ready to connect them once the motors bolted in . Not worth trying to line them up while lowering the motor , plus there's a chance of getting your hand caught/mashed if it drops while you're doing it .
PostPosted: Sun Apr 27, 2008 1:13 pm
I find it's easier to drop the engine down, and try not to put both shafts in at once. Get one on, and then manoever the engine around to get the other one on as well. If you are doing it yourself, a plank of timber can be handy to lever the engine around while handling the drive shaft at the same time with the other hand.
Don't forget to put the speedo cable on as you lower it down.
PostPosted: Sun Apr 27, 2008 1:38 pm
Mod corner :lol:
Yep dont worry about the shafts untill later when dropping a motor in.
If your fitting new engine mounts you are going to have enought trouble getting them to bolt up firstly
This is the only thing I have to add to the guys above
PostPosted: Sun Apr 27, 2008 6:34 pm
Hang on - its all good advice except that you need to have the inner CVs out of the road before you sit the engine down.
That means getting the car up on jack stands (safely) and dropping the top ball joints so you can draw the whole hub assembly back. Then you can just drop the motor in, locate and do up the engine mounts etc.
Then slide the joints into the pots. Becareful with the balls - liberally coat them in grease so they stay put other wise your going to hear the pitter patter of little balls all over the floor at inconvenient moments.
Mike
PostPosted: Sun Apr 27, 2008 6:59 pm
Mike_Byron wrote:
Be careful with the balls - liberally coat them in grease so they stay put other wise your going to hear the pitter patter of little balls all over the floor at inconvenient moments.
Mike
Did I see somewhere that you can wrap them in glad-wrap?
Dicko
PostPosted: Sun Apr 27, 2008 8:15 pm
d1ck0 wrote:
Mike
Dicko
MMM makes sense,
A little glad wrap couldnt hurt much? could it?
blokeinamoke wrote:
PostPosted: Sun Apr 27, 2008 8:43 pm
Mostly, once the have the balls a little bit into the grooves you can pull the glad wrap out. You dont really want it in there although it gets ppulverised very quickly.
Mike
PostPosted: Thu Feb 17, 2011 1:01 pm
whats the best grease to use for this?
PostPosted: Thu Feb 17, 2011 1:20 pm
Molybond, the grey CV greese.
If you undoo the top ball joints you can pull the hubs out far enough that the drive shafts pull out and give you plenty of room to move the engine into place.
Have a Nice Day.
PostPosted: Thu Feb 17, 2011 1:23 pm
I just leave the gladwrap in there.
If you only use grease at least one of the balls will fall out and roll somewhere so you can't find it. :x
PostPosted: Thu Feb 17, 2011 1:34 pm
cheers. and to clean the joins and all the balls in the first place? anything special to use?
PostPosted: Thu Feb 17, 2011 1:35 pm
Mods rock!
YAAAAAARRRRRKKKKK..............I disconnect the drive shfts from the Inner CVs, leaving the CV boots and GREASE (YAARRK) sealed away.
I don't mind getting dirty and even grease and oil, but CV grease is made from some kinda evil alian droppings.
PostPosted: Thu Feb 17, 2011 1:44 pm
I soak 'em in diesel. CV grease is evil.
PostPosted: Thu Feb 17, 2011 3:53 pm
Sticking it in....
Oh, I thought this was a thread about...
Doesnt matter, nothing to see here.
:shock:
Have a Nice Day.
