It is currently Mon Jul 21, 2025 8:22 am
 Post subject: HS6 Question
PostPosted: Wed May 07, 2008 8:02 pm
Hi,
Can someone please help me with my HS6 carb, I have been looking for the mixture screw, a picture would be great, but if not just a discrption is fine, its abit different from my old HS4!
Thanks in advance
PostPosted: Wed May 07, 2008 8:19 pm
If it is a HS6 it should adjust the same way as any other "HS" series carby. There should be a nut that the jet passes through under the carby.
PostPosted: Wed May 07, 2008 8:41 pm
yeah thats what I thought... It doesnt though dammit. The so called 'mini specialist' said it was a HS6...
PostPosted: Wed May 07, 2008 8:44 pm
Forum Graffiti
Does it look like this at the bottom?
If it does, this will help a lot ---
http://www.theminiforum.co.uk/forums/in ... ntry858512
PostPosted: Thu May 08, 2008 6:23 pm
yeah I think its the same as that at the bottom, but with a different top.. Ive taken a photo of it the other day but not to sure how to put it up on here....
PostPosted: Fri May 09, 2008 6:42 pm
My carb is actually a HIF44, not a HS6 like the rip off knob at a mini 'specialist' had told me, I should have known though as It came off a metro.
Can anyone please help me with the location of the mixture screw for a HIF44?
PostPosted: Fri May 09, 2008 6:46 pm
Forum Graffiti
The link I posted has the position for the HIF44 :wink:
PostPosted: Fri May 09, 2008 6:51 pm
PostPosted: Fri May 09, 2008 6:53 pm
Forum Graffiti
Stop encouraging people to be lazy Morris! :lol:
PostPosted: Fri May 09, 2008 6:55 pm
Wyan, you probably didn't get ripped off.
Due to rarity (and the usefulness on superchargered minis :wink: , and many other applications), HIF6 and HIF44 are generally worth more than HS6s which are fairly common and 'cheap' carbs in comparison.
PostPosted: Fri May 09, 2008 8:08 pm
no no no, I didnt buy it from there, I got it from england with the engine I bought. He is a rip off, Im not going into to much, but belive me he is. For starters, the rev counter doesnt work anymore, the bonnet wasnt alighed just bolted on, different screws have been put in all over the car, with most of them stripped, the door lock doesnt work any more, I payed for them to fix my temp and fuel gauges... not done. If it wasnt so far away from me it would have all been done, but unfortuanatly its my only car and I cant be without or I cant get to work.
And lastly the final price was WELL OVER double the original quote... I understand there are always going to be unforseen problems, but that is just ridiculus.
Anyway thats enough of a rant... Thanks guys for the help, oh and I tried the link put up yesterday but it doesnt work it says the site has been closed or moved, I wasnt lazy.
Cheers guys
PostPosted: Fri May 09, 2008 8:13 pm
Forum Graffiti
Work's for me :wink:
Here's the pics and a few quotes ---
It's number 4 - though somehow the drawing is a mirror image
No. 1, just above the adjustment screw, is the fuel in pipe.
No. 2, lower centre, is the fuel overflow from the bowl.
No. 3, above the spindle, is for the crankcase/engine breather. If you don't have it connected to your breather then block this one off with a blob of RTV silicon.
You probably have another short outlet pipe just below the piston chamber - it's the vent for the float and should be left open.
PostPosted: Fri May 09, 2008 8:20 pm
Beautiful, Thats the one I thought. I'll have a look see if the link works for me tonight, different computer (????) so it may work for me now!!
