It is currently Sun Jul 20, 2025 4:05 pm
 Post subject: what is this car?
PostPosted: Fri May 16, 2008 3:27 pm
hello my brother has acquired a new mini which we went and picked up today now it has no compliance plate and no number on the radiator cowling although there is a number above the radiator cowling reading FE695989 now i dont know what these mean it also has hooks for a heater and has rubber suspension 2 piece roof lining the cardboard looking sunvisors and a generator now i would much like some info if any one has an idea of what car this is...... thanks a lot...... i think it has been modified a lot because it has leyland guages and high back seats and a 998 duluxe engine...... thanks a lot fellas justin
PostPosted: Fri May 16, 2008 3:29 pm
I am guessing it is a roundnose.
PostPosted: Fri May 16, 2008 3:30 pm
yes sorry it has a wiper motor saying year 63
PostPosted: Fri May 16, 2008 3:34 pm
In that case I would guess it is an 850, though the heater hooks don't sound right as I don't think 850s were ever fitted with them. Is it possible it is an English model? Maybe a Super Deluxe. Either that or it could have started life as a Cooper. Or maybe somebody has just added the hooks. :wink:
PostPosted: Fri May 16, 2008 3:36 pm
no the hooks look like they have been factory fitted.... and the wipers are also on the wrong side like off an english car.....
PostPosted: Fri May 16, 2008 3:40 pm
I have an aussie made 850 shell from 63. it has factory heater brackets.
Carter,
check for a body id stamped into the firewall behind the master cylinders, letters about 1/2" high i think.
sounds like an 850 to me? sliding window doors? full front apron?
pics?
matt
Define 'wrong side' :lol: . I would suggest it is the 'correct' side as they didn't change until around 1969 or so. I believe you can tell if it is Australian or English by the roof gutter drain holes. I think Aussie ones are two holes drilled and UK ones are a slot, but would need confirmation.
PostPosted: Fri May 16, 2008 3:41 pm
it has wind up doors but 850 door catches.......i will see about posting some pics later on today or tomorrow....
PostPosted: Fri May 16, 2008 3:45 pm
yea roof cut outs are slots. full front apron with no cooling cut outs for brakes....also has a circular mesh thing behind the grill.
PostPosted: Fri May 16, 2008 3:52 pm
The change point on the wipers seems to be june july 68. (deluxes)
Most UK bodies had a slot for a roof drain hole, so did some early aussie ones tho. (CKD?)
That means it is a pre 68 shell if aussie.
where's the shifter? is it a factory hole? is there a magic wand hole covered up?
M
PostPosted: Fri May 16, 2008 3:54 pm
sounds 61 to 64 840 to me so far! Body number on bulkhead?
PostPosted: Fri May 16, 2008 4:02 pm
Sounds like a UK mini of some form or a really early Aussie 850 (1961) , how are the front seats secured at the front ?
PostPosted: Fri May 16, 2008 4:07 pm
ummm cant find the number on the firewall.......there is a hole where a wandering gear stick could have came out although there also is a hole where the gearstick comes out now and the both look factory?
PostPosted: Fri May 16, 2008 4:08 pm
seats are secured by seat brackets although they are leyland seats with head rests
PostPosted: Fri May 16, 2008 4:09 pm
My 1967 English-built Austin 850 Super Deluxe has the heater hooks as standard
Users browsing this forum: No registered users and 68 guests
