It is currently Sun Jul 20, 2025 4:29 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun May 18, 2008 6:05 pm
front face of the box, on a flat piece of metal on the right.
PostPosted: Sun May 18, 2008 6:14 pm
Oh sorry, yes, as Mick said, cast into case on front, can be hard to see in gunge behind oil filter / canister.
Cheers! 8)
Sir Alec! we are not worthy!
PostPosted: Sun May 18, 2008 6:24 pm
I have a 3 syc remote change someone can have if they want it.
$16 pick up only
blokeinamoke wrote:
PostPosted: Sun May 18, 2008 8:25 pm
thanks guys and girls
I'll check it out tomorrow.
PostPosted: Mon May 19, 2008 10:44 am
graham in aus wrote:
333 gets 'S' Tax too! (mk1 and appendix J Nb tax :lol: )
I'll take one for $15.00!!
:shock: :lol: :shock: :lol:
I wondered what people would think of that valuation..... though I don't have one :roll:
I've got one of the 'standardised' MK1 S cases, but it's the same as an 1100S, so maybe $13
PostPosted: Mon May 19, 2008 1:48 pm
simon k wrote:
22G68 - worth $5, 22G1128 - worth $10, 22G333 - worth the most at $15
Simon,
I'll buy every good 22G 1128 case you can supply me with for $10 please.
Dave
PostPosted: Tue May 20, 2008 11:25 am
sitnlo62 wrote:
Simon,
Dave
here you lot.... no-one bid on this one, and for $30 it comes with bits inside it (gotta be worth $20). And before anyone says 'yeah, but the diff housing is broken', since that one is a different colour to the rest of the box, and the bolts are missing, I'd say this fella bought the box just to get the diff housing for his own.... it's not a big deal to swap a diff housing over.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... NA:AU:1123
PostPosted: Tue May 20, 2008 3:05 pm
Simon,
Changing the Diff housing is a bigger deal than you think.
The case and the diff housing are a matched pair as they are line bored while bolted together.
Just like main bearing caps and blocks.
Big problems result when you squeeze those diff bearings out of shape!
Dave
PostPosted: Thu May 22, 2008 10:32 am
It's been done lots of times, you just need to bolt it up and check the 2 bores for roundness and alignment.
It's permissible to remove the 2 dowels if needed to get vertical alignment right.
It's also permissible to run without the top and bottom gaskets if necessary to make it round, just use Loctite 515 or similar metal-to-metal sealant instead.
So saith Sydney's #1 Mini engine builder (not me)... :lol:
If necessary, the diff housing can be decked, bolted on, and then remachined by anyone with a mill, boring head, and some nouse. :wink:
PostPosted: Thu May 22, 2008 11:14 am
I'm installing a Magic Wand diff housing onto a remote box. The alignment is so close a blind man would be happy to see it. 8)
David L
PostPosted: Thu May 22, 2008 5:32 pm
Just think about it, the alignment has to be about right. If it was just a slap dash bit of machining the diff gears wouldn't mesh properly.
PostPosted: Thu May 22, 2008 5:46 pm
see, I said it wasn't a big deal :wink:
PostPosted: Fri May 23, 2008 7:49 am
I guess it depends on your standards!
Tool Maker or Boiler Maker!!!!! ??????
i think I'll continue to use only matched pairs!
Dave
PostPosted: Fri May 23, 2008 9:38 am
Dave
might have to break out the internal micrometer and see what's what 'eh fellas :D
PostPosted: Fri May 23, 2008 9:41 am
Nah. This is a BMC product. Just eye-ball it. :wink:
Users browsing this forum: Majestic-12 [Bot] and 78 guests
