It is currently Thu Jul 10, 2025 7:08 am
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed May 28, 2008 9:14 pm
Forum Graffiti
Rookiepilot wrote:
Remember old Chinese proverb says, “Men who say it cannot be done, should not interrupt those doing it.”
Go for it Simon.
+1 8)
PostPosted: Thu May 29, 2008 2:36 am
:lol:
this looks interesting though
http://technology.newscientist.com/article/dn13545-nanomaterial-turns-radiation-directly-into-electricity.html
PostPosted: Thu May 29, 2008 9:49 am
cooper69 wrote:
Hey Simon, I do understand what everyone is saying about energy use and how you cannot create energy but I also think if science was in a bottle, we as society havent even taken off the lid yet so go for it.
For your invention you could have a battery pack in your car which you charge at night which then ran your hydrogen generator whilst you are driving. This way you are creating a zero emissions vehicle (if alternative power is used for charging eg wind solar) and if charged by normal power your car would probably be alot more efficient in terms of energy use than a standard car as coal powered generators in power plants are very efficient compared to internal cobustion engines
Good stuff mate
Phill
That way of doing it would work. It would probably end up being fairly cheap too.
Another idea that would work well if you could implement it properly: http://en.wikipedia.org/wiki/Crower_six_stroke
All I am saying is that charging of your battery while you are driving, then burning the gas to create power will not work. Read here for more info. http://www.ecogeek.org/content/view/951/
The reason it won't work is because of this law:http://en.wikipedia.org/wiki/Conservation_of_energy which was established in the 1800s, and has not been disproven in any way since. If you are not adding energy into the system, you will only lose energy from friction and heat. If you use another battery pack that you charge from the wall or solar, then you are adding extra energy and it will work. Methane would work as you are adding extra energy (in the form of gas), water (according to the theory) would work because you are improving the efficiency by using some of the heat energy that would otherwise be wasted.
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you are a mile away and you have their shoes.
PostPosted: Thu May 29, 2008 4:05 pm
Slow-Po
Man can legislate against the laws of physics, but he can't actually change them.
I'm sure that tonight's episode of a Current Affair should provide more fodder for this discussion, in the promo for the show I saw something that look very similar to simon's tub of Goulburn Valley peaches. 8)
PostPosted: Thu May 29, 2008 4:13 pm
we shall see..... they'll probably show the video of the bloke burning a hole through a big block of brass with his hydrogen powered blow torch. It was one of the first examples I saw of this stuff in use
there are lots and lots of websites selling my peach container in some form or other - having it shown on A Current Affair can only add credibility :roll: :?
the bloke from the alternate fuels board reckons there are heaps of mechanics around the country working on them
We've also been told that there's a mob in Adelaide converting trucks - haven't found any details tho
PostPosted: Thu May 29, 2008 4:25 pm
Slow-Po
:lol:
Be grateful that it's not Anna Coren endorsing it. :)
PostPosted: Thu May 29, 2008 7:40 pm
speedy wrote:
:lol:
gee, what a well researched, well reasoned and totally unbiased report that was....
oh, wait.... no it wasn't, what a surprise :lol:
PostPosted: Thu May 29, 2008 8:12 pm
I wonder how long it took ACA to find a pensioner with no teeth, who looked like he just stuck his finger in a light socket, to give credability to the alternative device.
Member VMCI #19
PostPosted: Thu May 29, 2008 8:17 pm
and no doubt the hour he spent talking to them took them all of 25 seconds to cut down to those 2 "questions" she asked him suggesting he was a stupid single income earner and had been ripped off
PostPosted: Thu May 29, 2008 8:22 pm
edmands_3 wrote:
Yes, cars can run off hydrogen, it is a perfectly valid fuel. No, you cannot split it using your battery then burn it again for a net power gain. You are using your battery to split it, then using the power from burning it to power your alternator to charge the battery again. As stated earlier in this thread, you cannot gain power like this. You split the hydrogen at 95% efficiency, burn it at 95% efficiency, and charge your battery using your alternator at 95% efficiency you lose 27% of your power (0.95x0.95x0.95 = 0.729). That is a best case scenario, it is very unlikely that you would reach anything like this efficiency.
I'm just trying to get my head around the maths involved in this , not doubting your calculations but I would have thought the energy produced by burning hydrogen and oxygen in a car's engine would be greater than the energy required to seperate water into the base molecules ? Even allowing for losses in generating the electricity through magnetic force and heat loss/friction in the engine I woulkd have thought it would produce more energy . Kind of like a supercharger , it might drain 5 horsepower (hypothetical value) to run but produce an extra 20 horsepower to make a practical gain (even with using more fuel) , wouldn't the increased economy or reduced fuel intake from running an engine on hydrogen enhanced petrol be greater than the extra fuel needed by the increased drag caused by the alternator having to work harder to produce more power ?
PostPosted: Thu May 29, 2008 9:34 pm
The energy from separating the water is the same as the energy from burning it. When you break it, you are using energy to break the bonds to split the molecules apart into their components. When you burn it, you are getting the same energy back as the bonds form again and it goes back into water again. The energy value is the same in both cases, because the start and end products are the same, with the same chemical bonds.
So basically, you use a certain amount of energy from your battery to split the water, say 20 units of energy, then you burn the water from that for say 17 units of power (in the form of motion though), then you use that motion to turn the alternator and charge the battery again with say 15 units of power. So you are making a loss of 25% overall because of the frictional and heat losses. Without losses, you would end up with 20 units of energy back in your battery again. (My earlier calc just used 95% as an example, I don't really know what the efficiency of your engine or alternator would be, most likely a fair bit less than 95%)
It works essentially in the same way as a rechargable battery. You have the reaction when the chemicals react together which produces power. Then you put power back into it as you charge it again, which splits the chemicals in the battery apart again. This leaves you where you started, but you have lost some power along the way from the inefficiencies. The only difference in this case is that instead of putting the water back into the battery, you are putting it out the exhaust, so you would have to top it up periodically.
Its also worth noting that not all chemicals act in this way with the breaking of bonds using energy and reforming the bonds releasing energy. Some work in the other way, the main ones are radioactive, where the element splits and the pieces that have split hit others molecules and cause them to split, releasing energy with each split (in the form of heat). This is why radiation is used as a power source as it naturally occurs with energy that can be easily released in a controlled situation. It is also what makes it dangerous because it can continue splitting if you don't control it and release huge amounts of energy. (Fusion is the opposite, where joining two chemicals together releases the energy, also in the form of heat)
I hope that all makes sense :lol:
PostPosted: Thu May 29, 2008 9:38 pm
Yes , that does make sense and answers my question , I wasn't thinking on that basic a level , I was thinking the combustible energy of a unit (1 cc , 1 litre , whatever the sample is) of hydrogen and water would still be slightly higher than the energy required to produce that unit .
Still a cool experiment though Simon , if only there was a way of using the heat generated by combustion to produce the electricity to extract the hydrogen .
PostPosted: Thu May 29, 2008 9:50 pm
This space for rent
Even then you're not going to reclaim 100% of the energy used to create the hydrogen fuel in the first place. By recycling the heat produced from combustion (and through regenerative braking, recycling the kinetic energy produced through motion) you get closer to that 100%, but it's impossible to get it all (or more) back.
PostPosted: Fri May 30, 2008 11:57 am
how about adding a turbocharger to use the exhaust to create the extra power needed - does that fit in the equation anywhere?
I'll certainly invest in a volt and amp gauge to monitor charging conditions
PostPosted: Fri May 30, 2008 12:15 pm
you are assuming the ability to convert heat to power with no loss - at best you would get 20 percent.
