It is currently Wed Aug 13, 2025 2:38 pm
PostPosted: Thu Jun 05, 2008 9:13 am
sports850 wrote:
Curly wrote:
They are brilliant , I've looked for something like that many times but never found anything .
They are great! My work uses them, (called nutsert, just a branding thing!) and every now and then i'll borrow the tool and I gotta say you look at installing things in a whole new way!!
Check ebay!
Matt
PostPosted: Thu Jun 05, 2008 12:00 pm
OK , someone with first hand knowledge then . What do you use them on and how strong are they rated (well , up to what grade can they do in the normal , usable sizes ?) ?
PostPosted: Thu Jun 05, 2008 12:06 pm
According to the website, they exceed the requirements for Grade 8.8 structural.
PostPosted: Thu Jun 05, 2008 12:20 pm
I saw that , but is that only the absolute top of the line ones that are difficult to use or are they all there ?
PostPosted: Thu Jun 05, 2008 12:37 pm
Hmmm, not sure of actual technical specs, but using the M6 round nutserts (not as much 'torsional resistance' as the hexagonal type in a hexagonal hole) I can tighten M6 bolts (Stainless steel) down to almost 80 ft/lb with the torque wrench, before they 'twist' in the hole. They do take quite a bit to move when installed properly, and when using stainless or zinc coated nutserts. The aluminium ones (imperial sizes mostly i think)are a lot weaker so i have heard, never tried!
I think it would be very hard to 'pull them out' once installed. It would depend on the material you have installed it in, but I know when installed into a sheet of 1.2mm 445 grade stainless, you can rest a few hundred kg's weight 'pulling' on them, sheet bends a bit, but nutsert and bolt stay firm! :wink: :wink:
They are good stuff!
M
PostPosted: Thu Jun 05, 2008 12:39 pm
Thank's Matt , that's exactly the type of info I was after .
Users browsing this forum: No registered users and 275 guests
