It is currently Fri Jul 18, 2025 2:50 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 28, 2008 5:07 pm
Fair enough, I just visions of the front lifting off the ground, and with a rear engine (probably the only way to do it without a huge transmission tunnel) not enough weight up front to hold it all down. Then when theres no weight up front the car probably won't turn very well under acceleration, or at all.
On topic though, engineering on a FWD mini here in SA will cost around $1500, as that includes track testing etc. But you have to find an engineering willing to go ahead with it all. Which would probably be the hard part. But if possible it's probably the cheapest part of it all.
Or you could buy a Sprite or MGB if you want to go bigger, fit 2 litre jap motor and engineer it easily for around $1500.
PostPosted: Sat Jun 28, 2008 10:10 pm
Then it wouldnt be a Mini then would it!!
PostPosted: Mon Jun 30, 2008 7:51 pm
Does anyone know of a company that would approve a RWD mini?
PostPosted: Mon Jun 30, 2008 7:59 pm
I beg to differ!
Sprite = RWD Mini :P
PostPosted: Mon Jun 30, 2008 8:33 pm
I beg to differ!
When the Morris 850 FWD Mini came out, it could easily outhandle the `RWD Mini', even on it's stocko 5.20x10 crossply cheesecutters... :lol:
Sprite = Austin 7 suspension (almost) with A40 Farina front end and better brakes... :P
