It is currently Mon Aug 18, 2025 5:20 am
 Post subject: Racing Seats
PostPosted: Sun Jul 13, 2008 6:02 pm
Just wondering for everyones who has racing seats in there minis, how wide are there seats and what width should i use?
I can get hold of a pair of racing seats cheap but i don't know what width they are or should be.
Mearcat wrote:
PostPosted: Sun Jul 13, 2008 7:05 pm
I have a velo milano in mine.
Their website www.velo.com.au doesn't have any measurements on it but they can fax you the sizes. Will try and measure mine tomorrow.
PostPosted: Sun Jul 13, 2008 7:23 pm
I have Recaros but were fitted from the factory like that
PostPosted: Sun Jul 13, 2008 7:25 pm
Simply measure between your B pillars and half it, if the seats are any wider it simply wont fit :wink: . You can also position the seats back on the B pillar which will put the shoulders between the rear windows but you need to be a long legged fella to reach the pedals.
From memory 500 or 550mm wide is around the right size but I may be wrong.
PostPosted: Sun Jul 13, 2008 7:32 pm
Ive got Sparco Sprints. THey just touch the pillar, and almost touch each other and i think there a pretty narrow seat.
PostPosted: Sun Jul 13, 2008 7:49 pm
thanks fella's
just wanted to know before i went and bought them without test fitting
Mearcat wrote:
PostPosted: Sun Jul 13, 2008 8:23 pm
Dion,
From memory the maximum width is about 540mm.
Any wider than that and they just wont fit.
PostPosted: Mon Jul 14, 2008 10:44 am
We've got cobra monaco in the race car, driver's set back and low, with the nav's further back and lower. If you stagger them you can get quite wide seats in, don't forget the passenger doesn't need to reach pedals, steering wheel etc.
(best pic I could find, and yes I do have long legs!)
Image[/img]
PostPosted: Mon Jul 14, 2008 5:54 pm
yes... yes you do have long legs by the looks of that :shock:
Mearcat wrote:
PostPosted: Mon Jul 14, 2008 8:27 pm
so how come you have the co-drivers seat so far back?
Mearcat wrote:
PostPosted: Mon Jul 14, 2008 9:29 pm
He's got long legs! :roll:
PostPosted: Tue Jul 15, 2008 11:03 pm
6'3" does give one long legs. Navigator is 6', and she is almost all leg (I'm a lucky bugger). The nav's seat is further back for a few reasons, firstly they wouldn't fit side by side, and also to improve weight distribution, it also sits basically flat on the floor. Even with being so tall we still both have heaps of headroom with helmets on. Obviously we had to move ignition and switchgear to floor crossmember, and the rally computer is mounted on the door, within easy reach, as well as a foot reset.
PostPosted: Thu Jul 17, 2008 8:39 pm
does anyone know who makes seat rails,
I have some monza seats that are small that I wanna fit
PostPosted: Thu Jul 17, 2008 8:44 pm
You can buy Cobra `Mini' rails (subframes) from Revolution Racegear, they bolt onto any Cobra seat and many others. Fit onto your stock seat brackets.
Karcraft lists them too, maybe cheaper. But check if they have stock.:wink:
PostPosted: Sat Jul 19, 2008 3:33 pm
cool i suppose you don't need an engineers certificate than?
Mearcat wrote:
