It is currently Mon Aug 04, 2025 8:40 am
 Post subject: noisy lifter?
PostPosted: Mon Jul 28, 2008 1:27 pm
I have a 998 A+ and has just gained a noisy lifter I think.
When you first start it up it is fine, then about 5-10 seconds later you can hear it start to go for its life.
When the thermostat opens up it quietens down to what it should be.
Is this anything to worry about?
Is there anything I should or do to fix it?
Have rechecked valve clearances and they are set correctly.
Thanks in advance.
Cheers Pete
PostPosted: Wed Jul 30, 2008 8:19 pm
Anyone?
Cheers Pete
PostPosted: Wed Jul 30, 2008 8:31 pm
Sounds nasty :? ....
Might need a bit more of a localized sound check. Lift the rocker cover off and see that it isn't a rocker on a worn shaft.
If it's internal use a long screwdriver as a stethoscope and try to chase the noise down on the block to a particular cylinder or area.
Might need a little more information..a check of valve clearances wouldn't go astray either..
PostPosted: Wed Jul 30, 2008 8:36 pm
The noise is coming from the tappet chest behind No 1 cylinder.
I have checked valve clearences they are all good.
Has me stumped as when the motor warms up the noise virtually disappears.
Cheers Pete
PostPosted: Wed Jul 30, 2008 8:42 pm
A bit of work involved in getting the cover off too, but at least it only needs two gaskets...might have to dive in for a look?
PostPosted: Wed Jul 30, 2008 8:51 pm
Cheers Pete
Not saying this is it but a maybe. When I stripped my motor down I had a devil of a time getting the cam out because the centre cam bearing had moved about a cm out of the web and it had been clipped by the cam follower and bent a tongue up till it was out of the way ( or maybe it still hit - I don't know , never heard it running)
David L
PostPosted: Wed Jul 30, 2008 9:08 pm
Is oil pressure ok at start up Pete :?:
PostPosted: Wed Jul 30, 2008 9:09 pm
Yeh oil pressure is fine hot or cold.
PostPosted: Wed Jul 30, 2008 9:21 pm
check tappet clearences with the engine running.
messy, but it will show up a worn lifter
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Jul 31, 2008 11:00 am
Does the noise get worse when you increase the rpm (hammering, tapping or a rattling type sound?)
:arrow: I'd recommend doing a compression test as it may be a stuffed head gasket.
:arrow: Check the distance the rockers are moving as it could also be worn lobe on the camshaft.
:arrow: Could even be the timing chain rattling/loose so check the timing as the mark will be jumping around.
My 5 cents worth.......good luck, hope you find the problem
Users browsing this forum: drmini in aust, justminis, winabbey and 99 guests
