It is currently Sun Jul 20, 2025 1:34 am
 Post subject: confused by the wheel?
PostPosted: Wed Jul 30, 2008 10:09 pm
I guess Im missing a bit? after the steering wheel is attached, what attaches the black horn bit to the wheel so It stays there.??
Picks would be a great help, this is my wheel
PostPosted: Wed Jul 30, 2008 10:41 pm
Looks like it may clip over the hex bolts that hold the wheel to the boss?
opps on second look, wheres the actual horn seat piece that sits under the cap? as it looks like there would be a section that the cap clips over
PostPosted: Thu Jul 31, 2008 8:29 am
You should have a round plate that attaches by three screw to the centre of the wheel.In your pic you can see the outline where the screws have been.
Then when you bolt the wheel on the large nut also helps to secure the plate onto the wheel.
Plastic centrecap then pushes onto the plate.
I can get pics tonight if you require :)
PostPosted: Thu Jul 31, 2008 9:42 am
Yeap it's a press fit over the plate.
PostPosted: Thu Jul 31, 2008 10:05 am
oh no..... missing, anyone have one or know where I can get one?
PostPosted: Thu Jul 31, 2008 10:20 am
You might try John or Danny at MiniKing, they usually has all sorts of bits and pieces laying around.... (02) 4648 1233
PostPosted: Thu Jul 31, 2008 10:25 am
You'd probably be better off buying another whole wheel to get the bit you want.
PostPosted: Thu Jul 31, 2008 10:55 am
I've tried no one will sell me one :cry: :cry:
PostPosted: Thu Jul 31, 2008 11:02 am
Have you tried Mini King?
PostPosted: Thu Jul 31, 2008 11:10 am
I got one from Mini King not that long ago.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jul 31, 2008 5:49 pm
The Mini King
looking at the photo You need three parts the plastic base under the wheel the diecast boss that fits through the plastic base then in the steering wheel on the top side of the wheel is a metal ring these are all held in place with three screws, I may have some new ones, I will check if you want, If not i can help with a second hand set
Regards
John Smidt
PostPosted: Fri Aug 01, 2008 7:44 pm
Here's the pick of the plate that you are missing,maybe it is lying around somewhere?
The plastic centre cap then pushes onto the plate,no other parts under the cap.
PostPosted: Fri Aug 01, 2008 9:17 pm
There's also a version with the same piece in black plastic rather than alloy.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Aug 01, 2008 9:30 pm
Thanks guys I've found an ausminster who is selling me the missing part for $20 plus postage, :D so I sould be set. Im going to restore the wheel so I'll post some picks when Im done
Thanks again :wink:
PostPosted: Fri Aug 01, 2008 9:37 pm
Thanks again :wink:
Oh that's good because my wheel has seen better days,maybe you can do this one as well :idea:
Users browsing this forum: No registered users and 72 guests
