It is currently Wed Jul 23, 2025 9:29 am
 Post subject: Two Problem!
PostPosted: Sat Aug 09, 2008 10:19 am
Hello all, i have two problem with the little car at the moments.
1st Brake: They make the car shake like mad, any idea what can cause that. I was thinking wheel alignments, but it's not that. Wrap disk....maybe!!!!
2nd: Is it normal to have intermittent windscreen wiper, i mean some time they work and sometime they don't :shock:
Any help greatly appreciated
Louis
PostPosted: Sat Aug 09, 2008 12:34 pm
Sounds like your discs are ready for replacement or a grind...warping generally causes that, you probably notice it more with speeds over 60kph.....
Wipers, well I am definately no electrical expert, but could be a bad earth, or could be internal.....will leave that for someone that knows more :D
PostPosted: Sat Aug 09, 2008 12:35 pm
Possibly warped discs, may even be out of round drums. More to the point when does it do it?
could be wiper switch or the motor requires re-winding/replacing but first will need to be tested.
 Post subject: Fr? Rr?
PostPosted: Sat Aug 09, 2008 1:02 pm
or something loose or broken in your front end...get it looked at quick.
PostPosted: Sat Aug 09, 2008 1:05 pm
Just like my indicators - they work -they don't - they work - they don't - they work ..............
Sorry couldn't help it :roll:
David L
PostPosted: Sat Aug 09, 2008 2:54 pm
Just like my indicators - they work -they don't - they work - they don't - they work ..............:roll:
I :lol: bet there is a ticking noise at the same time, best you get that looked at could be a break in the circuit :wink:
PostPosted: Sat Aug 09, 2008 8:09 pm
The brake are really bad at high speed, make the car shake, but visually the disk look very good!!!
PostPosted: Sat Aug 09, 2008 8:35 pm
Doesn't take much run out to cause massive vibrations. If you get them machined you'll be surprised at how far out they may have been. I used to be amazed at some that I've done, the bit/stones (depending on what type of machining) would barely touch the disk at times, had to have several cuts to get them smooth again.
PostPosted: Sat Aug 09, 2008 9:34 pm
:? Is the car vibrating at high speeds (you can feel it through the steering wheel and or the seat and or the floor) or when you apply the brakes at high speed (above 60 km/h) there is a vibration and the brake pedal pulsates and or the steering wheel vibrates etc....??
PostPosted: Sun Aug 10, 2008 10:11 am
The second option, when above 60k's the brake pedal and pulsate as you said, i am due for new disk am i????
PostPosted: Sun Aug 10, 2008 10:40 am
Louis
jack the car up one side at a time (very safely of course) and shake the wheel to see if there is any movement up or down or forward and back.
You are looking for a loose wheel bearing, worn ball joints, worn tie rod rubbers etc. Then if all is tight check the brakes. There should be any movement beyond normal suspension movement. It could also be a worn tie rod ball joint.
Mike
