It is currently Sun Jul 20, 2025 11:50 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sun Aug 10, 2008 7:30 pm
Kennomini wrote:
IMO with what you said you want I'd recommend changing the diff. It will depend on what you have now as to what you should get to accelerate faster.
Any mini friendly place should be able to do this, it would be a lot cheaper if you take the engine out yourself and simply take the diff in. That way you might have some money left over to tart up your carby a bit :wink: .
(I think you need to remove the engine to get the diff out :? can someone correct me if I'm wrong).
aside from the fact that I think changing the diff is a dumb idea, you can't just change the crown wheel, the gearbox needs to come off the motor, and the side off the gearbox to change the pinion.... and a gearbox refresh (layshaft, couple of bearings) is a necessity when you've got it that far open - you're looking at an $800 job
PostPosted: Sun Aug 10, 2008 8:18 pm
Mikemc wrote:
This must sound like a reply from an Wood duck,I want to spent
between 10 & 15K on a well done up original round nose, I am a poo mechanic but think I have sussed a guy in Brissy ( or welcome to sugestions) to look after it for me.
I want a car that has a QLD RWC that I can drive as a third family car,
I am mini to the core and know all the bad points and the goodies that come with buying the best car ever built!
Please get in touch with me if you know of a decent car in my price range that will fill my bill.
Thanks . Regards Mike
Hey start your own post :x :lol:
PostPosted: Sun Aug 10, 2008 8:44 pm
haha yea wtf :lol:
with $1500 you might have enough to
work the head, fit a free flowing exhaust and LCB extractors
PostPosted: Mon Aug 11, 2008 4:48 pm
Sorry,
That was pretty rude of me. Done after way too many red wines yesterday arvo.
Cheers Mike.
PostPosted: Mon Aug 11, 2008 7:43 pm
DJ,
A well modified cylinder head is all you need to increase the volumetric efficiency (the amount that the cylinders can be filled with the fresh fuel air mixture) of your engine enough to give you a very significant increase in performance. Far more than you will expect.
While cams and carbs are always first on the list for the novice tuner it is the cylinder head on the BMC A series engine that is the weakest link, the good news is that there is plenty of room for improvement!
Your standard cam, carb and exhaust should be fine for the increase in performance I think you are after and you will retain your original under bonet look.
Two other things you should ensure are right are the compression ratio and the ignition.
Dave
Users browsing this forum: crisonic and 64 guests
