Hanra wrote:
Does anyone on here have experience with the Opcon Autorotors that Link Automotive and High Performance Products sell.
http://www.hi-flow.com/ What compression ratio are people running with these? How much boost?
The Toyota blower setup that people use, is it purchased as a kit? What sort of $$$ figure? Can the SC type blowers be rebuilt?
What needle works well with a blown A-series and an S.U.?
My motor is a 1330, with the head and cam work done by GR back in 2000. What cam profiles suit blown A-series motors?
Opcon superchargers are one of the best out there. Volumetric efficiency of 98% or something close to that. SC only have around 50% I believe.
My set up had 8.5:1 comp and ran ~9psi, 12Psi being the max from a SC or bye bye rotor coating.. Rebuild?? just get another one i'd say..
Ben's kit includes all fitment parts required. SC12 and HIF carb you supply yourself.. My kit was around the $850 mark. I was desperate for the blower and paid $400, carb $150 NOS.
Check with GR on your cam specs as I had to change from an RE13 to RE13T as the overlap was too great. As long as the cam is not too wild I'd say it would be fine.
Needles I can't help you with. It will run with whatever you have atm, just get it tuned after it's running. (Rolling road not a necessity
