It is currently Sat Jul 19, 2025 9:49 pm
PostPosted: Fri Aug 22, 2008 11:49 am
Does anyone know whats involved in converting the late Metro A+ cable verto clutch system to a hydraulic verto system?
I can use the old non verto clutch assembly if I have to but I already have new parts for the verto system (lever, plunger, bearing and slave etc) which I would prefer to use.
Anybody?
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Mon Aug 25, 2008 9:02 am
just take the cable off - mount all your hydro bits and adjust,
my metro cable set up is working fine with pre=verto cylinder and arms ect.... i just had to make the pin that go's into the slave longer
backyard performance............. Aint it the best
PostPosted: Mon Aug 25, 2008 11:29 am
I already have a verto slave cylinder and I made the mounting bracket out of stainless.
So what you are saying is I don't need to change clutch or pressure plate etc. I just need to fit the hydraulic assembly?
Gig
PostPosted: Tue Aug 26, 2008 5:47 am
yea just the externals, it will work fine, as i said i have done the same but i used pre verto arms ect... off my old 850 motor on a 1275 metro.
PostPosted: Tue Aug 26, 2008 8:35 am
Thanks,
I take it you used a longer pin because you didn't have a verto assembly.
I'll give it a go a tell you how I go.
Gig
