It is currently Sat Jul 19, 2025 9:04 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Aug 30, 2008 6:14 pm
Greatly appreciate that link. Ive emailed the seller. 2 days to go, by his description it sounds like there brand new?
PostPosted: Sun Aug 31, 2008 10:30 am
[email protected]
Simon at morspeeds E-mail.............
Or at least I have corresponded with him via MSN
:P
Sir Alec! we are not worthy!
PostPosted: Tue Jun 08, 2010 10:09 am
Thread mine!!!!
The thought of re-building my engine is popping up again...
Just wondering if anyone has come across any small bore straight cut primary gear sets recently?
PostPosted: Tue Jun 08, 2010 4:37 pm
Also have a look at Swiftune
Nick Swift is to the UK racers what GR is to Aussie ones ....
He does a full set of roller bearing straight cut drop gears for £345.00
michael
PostPosted: Tue Jun 08, 2010 5:01 pm
Mods rock!
Jack Knight are still very much in business and they can do them.
PostPosted: Tue Jun 08, 2010 7:42 pm
Ok cool, Ill give that a try.
This was M.E.D.S response.
Sorry we do not keep the S/C gear set for the 998 engine. We normally take a set of 1275 and remove the rear bush and machine a new smaller diameter bush to suit the 998 crank add £40.00 to the cost of the S/C gear set for this to be carried out
I guess that would work ok? But Im sure I could get that done here if I just bought 1275 S/C gear.
PostPosted: Tue Jun 08, 2010 7:47 pm
Brad, there is always the option of swapping the crank for one with original step. I will have one to suit and we can work out the detail.
Steve
PostPosted: Tue Jun 08, 2010 7:54 pm
Mines a large journal crank though, are they any better? Steve, didnt you mention something to me along the lines of what MED suggested?
PostPosted: Tue Jun 08, 2010 7:59 pm
It would be pretty easy to machine up a floating bush (thicker than the 1275 one) so it fits the 998 crank. I could do it, easy as.
Problem is: the material, it needs to be silicon bronze as there is no real lubrication inside it. This is what the Minispares bushes are made from. But I have had no joy finding the stuff in solid bar or hollow bar form, here in Oz.
PostPosted: Tue Jun 08, 2010 8:07 pm
Jack Knight to rescue? It says its for 850cc? I would assume this would suit all small bore cranks? $450 for the full set, seems pretty well priced?
http://jackknight.co.uk/onlineshop/prod ... cts_id=136
PostPosted: Tue Jun 08, 2010 8:11 pm
Do a bit of internet research before sending your cash to Jack Knight. They have had some problems with the online store.
PostPosted: Tue Jun 08, 2010 8:22 pm
Oh really? Perhaps I should fax the order?
PostPosted: Tue Jun 08, 2010 8:30 pm
Yes there have been some problems. Google is your friend. :wink:
PostPosted: Tue Jun 08, 2010 8:36 pm
I figured your crank was large journal, I will have a large journal 1275 crank to suit. And yes, I did suggest a larger floating bush, but as Kev says, problem will be getting the right material. All up, I reckon swapping the crank over will be the simplest in the end. The Mini Spares SC drop gear set will be your best bet, and with your mileage, wouldn't bother with the tapered roller idler gear type, just go for normal SC idler.
Is your box A+ with large idler gear bearings or A series rod change? If A+, suspect you will not get small bore A+ SC drops :shock:
Steve
PostPosted: Tue Jun 08, 2010 8:37 pm
Fax them the cash and maybe they will fax you the gears. :wink:
Google Jack Knight Gears. :wink:
