It is currently Mon Jul 21, 2025 6:44 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
 Post subject: Dash
PostPosted: Thu Sep 04, 2008 7:34 pm
Here is my dash i made myself out of MDF and painted in 2 pac.
Steve
Classic Not Plastic
PostPosted: Thu Sep 04, 2008 9:32 pm
I knew I was missing one Steve :wink:
PostPosted: Thu Sep 04, 2008 11:23 pm
Kennomini wrote:
[Image
What are those indicator stalks off?
PostPosted: Fri Sep 05, 2008 2:14 pm
club77, just got that email mate, cheers for that. I'v got a CAD program at home i think so i'll make some adjustments to where the gauge holes are in the centre, (I have 3 instead of 2).
Just wondering however, did you also remount your main gauges so that they would sit flush like that? Are they easy enough to read now?
Also, how do you have your stereo mounted behind the dash, any other photos you have would also be appreciated.
So... I'm Seifer
PostPosted: Fri Sep 05, 2008 9:23 pm
When I remade my dash, the previous owner had made up a dash out of chip board and had bolted the gauges onto the back it is screwed in using 6 screws , so i don't know if he modified them at all to made them fit. I don't think so, just take the outside bit off.
the stereo was install professionally, but as I understand it just slides into the hole cut out.
As for photos, my portable hard drive with all my photos is playing up, when I get it working I will post some up.
"When you're in it up to your ears....it pays to keep your mouth shut!"
PostPosted: Fri Sep 05, 2008 9:49 pm
minidrifter wrote:
so a 2 peice dash and youd keep the original gauge cover?
im pretty sure someone on here did that, but i cant remember who.
I did something similar. I didn't want to mess about with detaching the instrument binnacle so i just cut a bit of mdf to the template up to the binnacle, stuck 3 holes for new guages, 2 holes for power sockets, a hole for my stereo, hole for air vent and hole for glovebox, glued some foam and then nailed, glued and stapled some cheapo Spotlight vinyl on...
I'll stick some pics up if i can find which PC they're on:
I posted about mine in this thread but i've not paid my hosting fees on my old website so the pics are not working.:
http://www.ausmini.com/forums/viewtopic.php?t=22390&postdays=0&postorder=asc&start=15
The other thing was how I attached mine - didn't want to drill holes so I used a couple of turnbuckles - makes it pretty easy to remove and reattach and it is rock solid too. Read thru my posts in that other thread for more info.
PostPosted: Sat Sep 06, 2008 12:31 am
Harley wrote:
Kennomini wrote:
[Image
Daihatsu Feroza, we had a couple lying around :roll:
PostPosted: Sat Sep 06, 2008 2:27 pm
I have a fibreglass dash as well in my clubby... well its a work in progress...
PostPosted: Sun Sep 07, 2008 8:48 pm
That's a bit more advanced than mine. What was the donner vechile for the gauges and controls?
PostPosted: Mon Sep 08, 2008 8:44 am
Its from a Daihatsu Mira. Dash is shortened, rounded, smoothed already. Just needs fine sanding and paint. Guages are going to be Sparco - Single speedo and single tacho.
