It is currently Mon Jul 21, 2025 1:02 am
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Jul 28, 2008 10:00 pm
where the door strikers are on the body. If it has an indentation for the door its a wind up window with a 850 gear stick hole mini minor unless there is hydro pipe brackets in engine bay then auto
PostPosted: Thu Aug 28, 2008 7:13 pm
Milatsmadmini
still waiting robbie??? :lol:
PostPosted: Thu Aug 28, 2008 9:04 pm
The Mini King
A couple of things I would check to help determine Model
does it have holes drilled for hood bows
Position of holes for mounting sun visors, close together or wide apart
Holes for striker plate 3 in vertical line or two in vertical line and one offset
PostPosted: Sat Aug 30, 2008 2:12 am
I'm Bert , where's Ernie
ok,
FINALLY got around to taking some pics, first time ive been out there with enough daylight to do anything in a long time, but anyway, pics will be up tmorrow.
however, from what i could see, there were no holes for the sun visors, there were holes drilled for the headlining all the way along.
also, is the door striker the part on the door, or the part on the pillar?
got some photos of the starter button hole aswell, i hope its near the clutch, ive never seen one before, otherwise i need a new floor :lol:
something else i noticed which grabbed my attention, on thge radiator shroud, it looks like the numbers have sort of been, rubbed out if you know what i mean?
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Sat Aug 30, 2008 7:17 am
The Mini King
I Am not that far from you If you want come out and i will walk you around some of the cars here and show you what to look for,
22 Graham Hill Road Narellan Phone 46481233
PostPosted: Sat Aug 30, 2008 9:36 am
minidrifter wrote:
ok,
Its normal on some Minis to have a starter button near the clutch housing...also normal for the rad shroud numbers to look "rubbed out" :D
PostPosted: Sat Aug 30, 2008 5:00 pm
pics have arrived,
for starters, the starter button hole, why do i have 2??
door strikers
lack of sunvisor holes
headlining holes
"rubbed out" radiator shroud
firewall
PostPosted: Sat Aug 30, 2008 5:10 pm
thanks for the offer john :)
had a walk round your yard a couple of times now, i was the p-plater kid who owned the slightly smashed blue clubby that you had a look at and told me to get rid of my weber for a 1.75" su :lol:
i'll see what im doing in the next week or so, and i might take you up on that offer, thanks again :D
PostPosted: Sat Aug 30, 2008 6:53 pm
The Mini King
The body shell is a wind up window model ,1965 to 1966 from what i can see
 Post subject: Floor Starter
PostPosted: Sat Aug 30, 2008 8:02 pm
minidrifter wrote:
pics have arrived,
The starter "button" (switch) is back right beside the gearshift....those are subframe mounting holes.
The plate top left (4 self tappers) is covering the original 850 "pudding stirrer" gearchange.
 Post subject: Roof Rack
PostPosted: Sat Aug 30, 2008 8:07 pm
minidrifter wrote:
headlining holes
The top one (through the roof) is either a radio aerial mounting or maybe for a roof rack crudely bolted to the roof.
PostPosted: Sat Aug 30, 2008 9:34 pm
Yep the push start is further back and those holes are for the Subby
Door Strike looks looks like itrs been out of Alieanment for a long time
hate to think that some one would put a areial or a Roof rack thier but hay many have done scarier things (get some one who knows how to weld here to fix it
Get a got grinder and a Twist lock wire wheel (if you want Pic's I'll gladly show you what works well) to find what is hiding under paint on the shroude and fire wall and anywhere else you want to find holes
PostPosted: Sun Aug 31, 2008 12:44 am
my guess, that was an aerial that was poking through the top,
so the starter button would be up near where that metal plate with the 4 self tappers would be? i have no idea, ive never ever seen one before.
so gaf, you reckon if i use a twist lock wire wheel to take away some of the paint, that'll reveal the other numbers, i dont wanna go nuts with it just yet, i dont wanna find anymore holes, i mean, im already lost with the bloody subframe mounting holes as it is :lol:
im just confused as to why there are no sunvisor holes, and why there is no id plate anywhere on the car, nothing from the boot could help to identify it?
thanks again for all your help
robbie.
PostPosted: Sun Aug 31, 2008 8:00 am
the starter button would be back near the cross member offset to the driver side
try some paint stripper on the shroud as the wire wheel will take out any lightly stamped numbers the stamping was not always the best
the subframe bolts are dished to fit flush into the floor
PostPosted: Mon Sep 08, 2008 12:27 am
also, just thought i should mention,
it has dry suspension, and no paint stripper on it as yet, no $$ to do anything.
