It is currently Sun Jul 20, 2025 10:26 am
PostPosted: Fri Oct 03, 2008 2:03 pm
I've never greased my nipples.
I was gonna buy a grease gun for $7 at a fete a few weeks ago. Might go and buy one this weekend as I wanted to spend a bit of time on the car this weekend.
What sort of grease is used, is there different sorts for different nipples??
PostPosted: Fri Oct 03, 2008 2:09 pm
Give Ash some flowers Nick .
I use EP2 grease in all the suspension nipples :wink: I think it cost about $12 or so for a tube (450g) of grease last time I purchased one. I have one sitting in reserve for when this one runs out.
PostPosted: Fri Oct 03, 2008 2:12 pm
Just use a general lubrication grease in all nipples - back in the 60's I used to use graphite grease - nowdays I use a Molybdenum grease.
David L
PostPosted: Fri Oct 03, 2008 2:56 pm
where are the grease nipples for the trailing arms?
PostPosted: Fri Oct 03, 2008 3:03 pm
On the side of the car. They are covered up by little rubber bungs. You might have to wipe away the old grease that is now covering that area. You should see it just past the front side of the rear wheel arch.
PostPosted: Fri Oct 03, 2008 3:09 pm
Yeah alot of people don't do the rear arms and wonder why their rear suspension ceases up :wink:
PostPosted: Fri Oct 03, 2008 7:15 pm
The car is supposed to be greased every 3000miles or 5000km.
The vastly superior Morris 1100 only has 5 grease nipples. :wink:
PostPosted: Fri Oct 03, 2008 7:20 pm
Hmmm what part of the front suspension gets none then? :lol:
PostPosted: Fri Oct 03, 2008 7:49 pm
The only grease points are the ball joints and the gearchange.
The upper suspension arms and the trailing arms have roller bearings and no grease nipples.
PostPosted: Fri Oct 03, 2008 8:11 pm
It'll never catch on.... :wink:
PostPosted: Fri Oct 03, 2008 9:26 pm
I'm Ernie , Where's Bert ?
hmmm good topic
ive never greased my car yet :oops:....another one for the to-do list
EDIT: how would you grease the dizzy?? :?
00' Forester GT
PostPosted: Fri Oct 03, 2008 9:32 pm
1. when you fit new points you smear a little HMP grease on the cam.
2. You are supposed to put a drop or 2 of engine oil in the top of the shaft (under the rotor) every pancake day. :P
PostPosted: Fri Oct 03, 2008 9:35 pm
Caponix wrote:
hmmm good topic
Lachie, if you don't know the last time they were done, do them now! Same goes for oil and oil filter I reckon.
You only grease the cam lobes on the dizzy shaft where the plastic contact thing contacts the lobes of the cam. Only needs A LITTLE BIT on there :wink:
You can also put a couple drops of engine oil into the top of the spindle axis. DO NOT REMOVE THE SCREW. But that's about it for the dizzy.
<edit> the good doc was way too fast for me
PostPosted: Fri Oct 03, 2008 9:44 pm
yep no idea when they were last done, be at least 6 months+ id say at least :shock:
yep ive allready requested next weekend off work so i can do an oil change, my rear wheel studs (been too busy so still running 12"s+10"s :roll: ) along with another wash/wax/polish, and a bit more 'construction' interiorwise...:roll: ill get there eventually :lol:
00' Forester GT
PostPosted: Thu Oct 09, 2008 2:29 pm
I bought myself one of the STM grease guns we have in the warehouse, and a $6 450g tube of Molygrease EP2.
I plan to give the front end a good going over while I have it up on stands this arvo.
Users browsing this forum: Bing [Bot] and 98 guests
