It is currently Fri Jul 18, 2025 4:49 pm
 Post subject: 3 gauge cluster
PostPosted: Wed Oct 08, 2008 5:47 pm
Hi every1 my names jarred im new, i have a 75 clubbie s with a 3 gauge instrument cluster but the third one is a clock. its so frigging loud it SH*ts me to tears. anyway i was wondering if i replace it with one that has a tacho instead is it a straight swap over or will i have to wire the tacho in?
Thanks
PostPosted: Wed Oct 08, 2008 5:57 pm
If you swap the whole cluster you will need to wire the tacho in, shouldnt be to hard. My clubman never came with a standard tacho but it still had the sending wire the comes from the coil to the tacho just laying there. Its a white with black tracer wire i think.
PostPosted: Wed Oct 08, 2008 6:00 pm
thanks for the help champ
PostPosted: Wed Oct 08, 2008 6:38 pm
I'm Bert , where's Ernie
you can also just take the clock out and replace it with the tacho, saves you buying a whole new unit, might save you some $$, sometimes the 3 guage clusters sell for big money.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Wed Oct 08, 2008 6:54 pm
are the clock clusters worth much compared to the tacho ones?
PostPosted: Wed Oct 08, 2008 6:59 pm
No. They were fairly common in Marinas (so you could tell how long it took to get to 100kph).
PostPosted: Wed Oct 08, 2008 7:00 pm
id say no, the clock clusters came on mini k's, whereas the tacho clusters came on clubman s'. If you PM mattsmadmini he wired in a tacho to his cluster, he originally had the two, then added the tacho in later.
PostPosted: Wed Oct 08, 2008 7:02 pm
Thanks guys for your help !
PostPosted: Wed Oct 08, 2008 7:04 pm
High heel ninja
I've got a few here, is your a orange or white needle cluster?
Doogie
PostPosted: Wed Oct 08, 2008 7:07 pm
They are orange needle
