It is currently Fri Aug 22, 2025 8:30 am
PostPosted: Wed Oct 22, 2008 7:49 pm
Is their a proper way to set the tensioner on an A+ 1275 or do you just simply do it by feel?
PostPosted: Wed Oct 22, 2008 7:54 pm
:shock: Yeah, bin it and put in a double row timing chain :D
Personal preference
PostPosted: Wed Oct 22, 2008 8:08 pm
What he said- ^^^ :wink:
Some people fit a duplex chain and keep the A+ tensioner too. It's not designed for a duplex but apparently works, sort-of. I've never felt the need.. :lol:
Note that most chains now are poorly made (compared to the Renolds UK chain of yesteryear)- they are loose when new.
The exception is the Jwis endless chain (made in Germany, around $60), Rolon chain is pretty good too.
PostPosted: Wed Oct 22, 2008 8:20 pm
Yes, by feel, enough to take any slack out of the chain, then just a little tension. I have been running the A+ tensioner on my race engines for years now without any dramas. These A series blocks have been line bored so the distance between crank and camshaft has been altered and the tensioner takes out any slack.
Steve
PostPosted: Wed Oct 22, 2008 9:12 pm
Thanks, all done now.
I used a Rolon single row chain, permertight on the gasket and loctight on the bolts, should all be good fingers crossed :roll:
Users browsing this forum: No registered users and 187 guests
