It is currently Tue Aug 05, 2025 1:26 am
 Post subject: Valve train question
PostPosted: Tue Oct 28, 2008 9:30 am
Are all push rods interchangeable? ie same size. If I find I have a couple of wonky ones can I pinch some from another motor?
David L
PostPosted: Tue Oct 28, 2008 9:35 am
There are 2 different lengths,,, small bore,,, & big bore,,, the rest of the shape differences don`t really matter
PostPosted: Tue Oct 28, 2008 9:02 pm
Whilst on the subject of pushrods, shouldn't the ends of the pushrods that go into the cam follower match that cam follower. If so you can remachine the end of the pushrod down then just buy new followers? Would the end of the machined pushrod be hardened in any way? :?
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Tue Oct 28, 2008 9:08 pm
Yes both ends are hardened.
