It is currently Sun Jul 20, 2025 10:11 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Feb 10, 2005 8:16 pm
I modified my lights by removing the single filament fitting and putting a double filament fitting used for the brake/park lights from a couple of old assemblies I had lying around.
Just bend up the tabs to remove and push them down flat again when you instal though I did add a drop of aradite to make sure it would move.
I'm not sure if the fittings from a clubbie will fit,you may need to use the ones from a round nose.
PostPosted: Thu Feb 10, 2005 9:23 pm
I reckon put a 5" Hella foglight on the boot and fit a bloody dash switch.. 8)
Basic and it works. Also can be used to get revenge on driver following with high beam on. If any one fits a manually operated reverse light it must have an internal warning light for when it is switched on.
Chris
Everything I like is either
PostPosted: Sat Feb 12, 2005 6:25 am
Or a big spotty...Yer I know its illegal but I was spotted by a truck driver once when he thought I was to close to his arse :roll:
PostPosted: Wed Feb 16, 2005 9:19 am
Sorry for the delay in getting back.
Thanks to all of the advice, it has been very helpful!
I have a couple of old tail lights with broken indicator plugs, so i think I'll have a play with these first (junk anyways). If I don't have any joy then the 'fog' light on the boot will be my next choice.
Any know the rules for adding one in QLD (max wattage etc)??
Matt
