It is currently Wed Jul 02, 2025 4:02 pm
 Post subject: carby question
PostPosted: Fri Nov 21, 2008 5:25 pm
g'day all just wondering what causes a carby to spit out petrol out the shaft and also where the vacuum advance goes the shaft is the one that is connected to the butterfly...... i hope that makes sense
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: carby question
PostPosted: Fri Nov 21, 2008 7:18 pm
'spitting' petrol out of the carb anywhere other than down the throat is not at all normal!
'spitting' fuel at any point is not at all normal for that matter
can you describe in a bit more detail what's happening
IE when the butterfly open / closed, idling, revving.... ??
PostPosted: Fri Nov 21, 2008 8:03 pm
comes out both idling and revving...... i think its just the carb out of tune but i want to know what you guys think.....how do i adjust the carb so it runs but may still need a bit of fiddling around with but will run and revv? i know that you adjust the nut under the bottom just how many turns etc any body know>?????/
1970 mini k
1975 leyland
PostPosted: Fri Nov 21, 2008 8:27 pm
sorry carter,,, its too general a question with very little to go on
but it could be way lean,,, try turning the mixture nut down a few flats,,,, maybe till the idle frops a bit & maybe the spitting will stop
have you got some oil in the dash pot???
PostPosted: Sat Nov 22, 2008 9:14 am
oil is in dash pot......it just doesnt rev you put the accelerator down and it goes couch couch couch brrrrmmmmmm if that makes sense?
1970 mini k
1975 leyland
PostPosted: Sat Nov 22, 2008 9:31 am
Check your timing first ..........
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Nov 22, 2008 9:34 am
timing has been done it isnt the timing did it yesterday cause it was backfiring because the carb wasnt tightened it vibrated itself out so fixed that problem yesty no more backfiring.
1970 mini k
1975 leyland
