It is currently Sun Jul 20, 2025 1:20 pm
PostPosted: Tue Feb 08, 2005 1:34 pm
Check out this link....
http://www.dpi.wa.gov.au/licensing/fees/exam.html
Tells you the fees for inspection and moving, moving permit from what I understand is good for one day. To and from inspection only. about $15 for movement about $53 for inspection.
Badly designed site but useful.
Above link for WA rego purposes
If it squeaks and leaks, then its sure to be a mini
Building a dream one nap at a time....
http://spaces.msn.com/members/derbydog/
PostPosted: Sun Feb 13, 2005 12:08 am
I just realised an important thing I'll need for licensing, that I don't have.
A 12" spare :(
Will it have to be the same wheel or will any 12" rim and legal tyre do? My tyres are 165's, would they allow 145's on the spare? I dont see why not, as "Emergency Wheels" are totally different to the rest :roll:
Anyone know the technicalities here?
www.crazybitchracing.com
PostPosted: Sun Feb 13, 2005 6:44 pm
Don't take the spare!
If it is not there they can't knock it!
PostPosted: Mon Feb 14, 2005 12:19 pm
You don't NEED a 12" spare. A 10" spare will do, as if you have a flat on the front you can put a rear tyre on teh front and trhe spare on the rear. This is what you do on a modern FWD car with a yellow space saver spare anyway. Hey, just paint the 10 rim yellow for an authernic space saver look.
Technically, you do not have to carr a spare, and the spare does not have to have road legal tread in VIC anyway. But as soon as you fit a spare with low tread the car is unroadworthy supposedly. A car presented for a roadworthy with a space saver fitted will fail anyway.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Feb 22, 2005 6:17 pm
Damn, in WA we have to have an approved immobiliser fitted :roll: grrrr
PostPosted: Tue Feb 22, 2005 6:20 pm
If the vehicle is over 25 years old... it doesnt need one ;)
PostPosted: Tue Feb 22, 2005 8:07 pm
I have 12 inch wheels and a 10 inch spare. If i get a flat on the front it'll be a pain in the posterior as 10inch wheels won't fit over my brakes :x I will have to take the 12inch off the back, put the spare on there then put the good 12inch on the front. Luckily i have another set of the same wheels here just waiting to be redrilled when i get the $$$$$ :mrgreen:
Bob Slattery
PostPosted: Wed Feb 23, 2005 7:50 pm
one of the blokes i work with is right into old cars, mainly mini's and he said just to rock up to the mechanica and ask for the form they they use when checking your car then go home and go over it your self as if you were doin his job, that way if he tries to fail you on somthing you can bring it to their attention that the item is worthy
if its broken fix it, if you cant fix it replace it
