It is currently Sun Jul 20, 2025 9:05 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 04, 2008 8:30 pm
Skender do you have rods and crank for this block??
If you want the block measured, ive got snap gauges.
PostPosted: Thu Dec 04, 2008 9:04 pm
thansk miniman but not sure I'll be doing any of this stuff meself ... .will be entrusting most of this to who ever does the machining/build....
G'day Scott, I plan on using the rods and crank out of the 1100s block I have .... apparently this means I have to get +30" crank thrusts??
I like to get mine around .010-.020" deck height... :wink:
hmmmm sounds interesting ..... tell me more? I take it you mean positive clearance? I've heard a bit about this. Does this raise your compression?
PostPosted: Thu Dec 04, 2008 9:12 pm
Pistons down the bore.
Race motors often are set flush. But remember when you rev it the crank flexes, if set flush all the head clearance you have left is the gasket.
I like another .010" insurance... :wink:
PostPosted: Fri Dec 05, 2008 8:19 am
Hi Skender,
Whe you finally measure the bore and know what size it is for sure will you please let us know?
I am very curious!
Dave
PostPosted: Fri Dec 05, 2008 10:13 am
sitnlo62 wrote:
Hi Skender,
I am very curious!
Dave
will do :wink:
Users browsing this forum: Phil 850 and 71 guests
