It is currently Sun Jul 06, 2025 11:22 am
 Post subject: BINI Specs?
PostPosted: Sun Dec 14, 2008 6:57 pm
Where is the best place to find accurate specs on MINI's from 2002-2005?
PostPosted: Sun Dec 14, 2008 7:21 pm
Sales brochures.
What do you want to know specifically?
PostPosted: Sun Dec 14, 2008 7:36 pm
Basically want to compare the differences between the different years and what was upgraded on the newer models.
PostPosted: Sun Dec 14, 2008 9:18 pm
Check out the FAQ page on MINI2.com all the details are there :)
PostPosted: Thu Dec 18, 2008 9:18 pm
the R53 came in in 2004, with 3kw more power in the Cooper S and I think the Cooper stayed the same, plus the R53 seemed to be built better with better quality finishes
BUY A R53
PostPosted: Fri Dec 19, 2008 10:30 am
Next Q? Can you put a towbar on them?
PostPosted: Fri Dec 19, 2008 12:03 pm
Not on a cooper S because the factory fit the exhaust with a centre exit.
The non charged car can tow something if you really want, but the gearboxes dont last under the cars own weight let alone something else.
:D
PostPosted: Fri Dec 19, 2008 12:50 pm
Thought that might be the case.
PostPosted: Fri Dec 19, 2008 6:09 pm
yes you can fit a tow bar to a cooper S, you need to move the centre pipes to to either side. ( PM kenhenry on www.mini2.com he has done it!)
PostPosted: Fri Dec 19, 2008 10:46 pm
Yes you can, MINIFINI sells a kit for the S. :)
