It is currently Fri Aug 15, 2025 6:22 pm
 Post subject: Back end gets loose
PostPosted: Fri Dec 26, 2008 11:19 pm
I'm running Cooper S discs (no booster) with 5/8th rear cylinders and under quick/heavy braking while cornering the back gets a little loose/wobbly. it's easily controllable I've just noticed it a few times.
Is this a normal thing?
PostPosted: Sat Dec 27, 2008 6:33 am
Yes under heavy braking with good front discs, LOTS of weight gets transferred from rear to front. Moral... don't do emergency braking in corners, unless your reflexes are FAST!
Years ago I had a pic of Peter Manton? braking for creek corner at Warwick Farm, with both rear wheels off the ground... :shock:
PostPosted: Sat Dec 27, 2008 9:07 am
NAV-MAN
I have had a few nervous moments while braking into a corner. But that was in NAV with drum brakes and very little fuel left so the rear was lighter than normal.
The hardest thing I found to do was get off the brakes and get onto the accellerator when going sideways to pull out of it.
Lift off oversteer is scary fun too :twisted: :wink:
I miss driving NAV, must get round to fixing him one day.
 Post subject: Tyres
PostPosted: Sat Dec 27, 2008 9:23 am
Do you have the same tyres on all four wheels :?: plenty of tread :?:
PostPosted: Sat Dec 27, 2008 11:45 am
Had you just eaten a curry or had my mothers cooking?
 Post subject: Re: Back end gets loose
PostPosted: Sat Dec 27, 2008 11:47 am
no... ;)
PostPosted: Sat Dec 27, 2008 7:21 pm
Silly question are both rears adjusted equally? when they are out of adjustment Lillee tends to not break straight. When they are all's good
PostPosted: Sat Dec 27, 2008 8:55 pm
Break or brake? :D
PostPosted: Sat Dec 27, 2008 10:53 pm
Dab the brake, flick the wheel and keep it pin'd :twisted:
Brings back fun memories :D and some of soiled undies :shock: :oops:
PostPosted: Sat Dec 27, 2008 10:59 pm
well why the hell are we braking heavily in corners?
slow in fast out.
or am i missing something?
the mokeman cometh...........
PostPosted: Sat Dec 27, 2008 11:01 pm
simon k wrote:
no... ;)
It's normally when people pull out in-front of me on roundabouts :evil:
I guess I just have to be ready for it in the future.
PostPosted: Sat Dec 27, 2008 11:04 pm
pay attention to 9YaTah's post.
what tyres are you running, how old, and what sort of condition?
It could be an important factor.
KB
PostPosted: Sat Dec 27, 2008 11:08 pm
Brand newish Falkens on all four corners, that's not an isue this time.
PostPosted: Sun Dec 28, 2008 6:43 am
Back end getting loose :roll:
PostPosted: Sun Dec 28, 2008 4:52 pm
Minis transfer weight easily under braking, they will get light in the bum just from backing off. You need to be aware of this at all times as they will spin quite easily if you do the wrong thing. (though no where near as bad as an early 911 Porsche)
You can brake in a corner but you will need to steer the car to keep it pointing straight.
People that say "don't brake in corners" just don't live in the real world! I can think of a lot of places where you just have to brake in corners. It is not as if you can run a red light with the excuse "I can't brake in a corner" You have to be able to stop the car at any time.
My advise is to find somewhere open and safe and practice braking and backing off in corners. But find somewhere safe to do it.
Users browsing this forum: Bing [Bot] and 189 guests
