It is currently Fri Aug 15, 2025 11:30 am
 Post subject: clutch thread size
PostPosted: Mon Dec 29, 2008 9:39 am
O.k. probably been asked a few times before but i just wanted to know the tread size and pitch on a VERTO flywheel can't seem to find anything that wants to fit nicely in there 3/8 unc wobbles around like nothing ..
so if you could help out that would be great
thanks Beanie :D
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Dec 29, 2008 10:00 am
definitely wouldn't be UNC, as UNC is normally only used in the alloy housings - you've obviously tried a 3/8 UNF like a normal flywheel?
which bit are you trying to find a bolt for anyway? I've never seen how a verto flywheel holds together, want to put up some pictures?
and I doubt that ones been asked before!
PostPosted: Mon Dec 29, 2008 10:28 am
M10x1.5 used on puller bolts for Verto. :wink:
Users browsing this forum: No registered users and 347 guests
