It is currently Tue Jul 01, 2025 8:07 am
PostPosted: Sun Jan 04, 2009 9:29 am
Hi All,
Does anybody know the bleed sequence for brakes with the late type master cylinder.
Thanks
PostPosted: Sun Jan 04, 2009 1:49 pm
I went through hell recently bleeding a `78 tandem one. :x
I have since been told that one trick is to bleed LR & LF together, then repeat for RR & RF.
PostPosted: Sun Jan 04, 2009 3:44 pm
yeah,,, just bleed "A" front & "A" rear at the same time on the usual "Aust" Front/rear type tandem brake systems
but the UK & Jap type diagonal systems i expect will need "A" right & "A" left open at the same time,,, at a guess
PostPosted: Sun Jan 04, 2009 7:36 pm
Hmm Its a 93 Mk 3 Jap shell with japaneese master. I have bench bled the master now and it seems fine out of the car but once installed back in the car i cant get fluid through the top output
I have a gut feeling that the brake pedal is different and not allowing enough travel ( the pedal box is from a early system)
Its not easy to find much info on theese later systems, it seems i may have to try and find a jap pedal box.
Does anyone have any knowledge on theese systems and confirm or deny my theory
PostPosted: Mon Jan 05, 2009 5:04 pm
The jap ones generally have a vacuum booster attached to the master cylinder is this the case with yours? and the cylinder mounts horizontily and uses a bellcrank assembly to operate it. Should be able to use the old pedal but will need the jap bell crank
4efte powered Clubman
supercharged 998 race car
