It is currently Sun Jul 20, 2025 10:01 am
 Post subject: Rear S drums
PostPosted: Wed Feb 16, 2005 6:06 pm
i have some new rear S Drums with the 1 inch step on them i was just wondering if anyone has any tips on fitting them. i know i need longer studs and set screws. does anyone have any tips on knockin the studs out. i'm Fiiting them because i have discs and i need to even out the front and rear track.
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Wed Feb 16, 2005 6:14 pm
I sit the flange on the vice, hit stud with BFH... 8)
You can fit the new ones the same way (oil them first) or press them in with a press, or use the vice and a couple of sockets. :wink:
Or, wind a wheel nut on the stud, with some washers underneath it.
Users browsing this forum: Bing [Bot] and 81 guests
