It is currently Thu Aug 14, 2025 10:34 am
PostPosted: Tue Jan 20, 2009 7:36 am
Has anyone done it without persuading the body with a hammer or angle grinder?
PostPosted: Tue Jan 20, 2009 7:38 am
Check out Nicks in members gallery , mounted in the inner guard without any obvious cutting ,
http://www.ausmini.com/forums/viewtopic ... &start=195
PostPosted: Tue Jan 20, 2009 7:46 am
Yes that thread was what triggered my question. I mean straight on the radiator between the radiator and the inner guard grill.
PostPosted: Tue Jan 20, 2009 8:09 am
The rover thermofans from the late 80s bolt onto the radiator grille (but on the wheel side) with no body modifications at all. Don't even need to drill holes.
:D
PostPosted: Tue Jan 20, 2009 8:17 am
So as long as you have a good seal between the rad and the cowl on the body you're fine??
I wanna run a thermo fan on the Moke, and get rid of the engine fan.
 Post subject: Cool me down
PostPosted: Tue Jan 20, 2009 8:35 am
Rover Cooper
you dont really need to have a secure fit, the fan on the rover will suck the skin off a custard from about 50 metres and it has better vaccuum than Mick Jaggers Lips around a polly waffle, :wink: :wink: so all you gatta do is fit it opposite the radiator, supply some electricity and turn it on. :shock: :shock: Mine works fine in this hot weather, not a problem. :roll: I have 2 fans the original one and the one Rover supply with the A/C kit.
PostPosted: Tue Jan 20, 2009 9:08 am
Just make up a big rubber seal that gets clamped between the shroud and the body.
As for motorkhanas, I'd be wanting to stay with the inboard factory fan so the external one isn't damaged from stones and crap.
Put some flyscreen over it if thats the case.
PostPosted: Tue Jan 20, 2009 9:46 am
yup, fitted one to my sons mini. it's an 8" fan between the inner guard and the radiator. went in no worries. it is a very thin fan though, so u will need to source one of those.
PostPosted: Tue Jan 20, 2009 10:10 am
How did you attach it to the radiator??
PostPosted: Tue Jan 20, 2009 10:16 am
An 8" fan should attach to the radiator grille without body mody. You'd just need some big washers and some long screws.
 Post subject: re: thermofan
PostPosted: Tue Jan 20, 2009 11:23 am
I managed a 9" thermofan in that small space without cutting/bending/hammering - wouldn't fit much more though! You could possibly mount a bigger thermofan if you put it on the outside (wheel arch side) as it's external to the engine bay then - ie. you could fit a 10" or 12". This is my next upgrade plan (a SPAL would do nicely.)
PostPosted: Tue Jan 20, 2009 5:57 pm
Give Ash some flowers Nick .
Poeee, I have moved my thermo fan into the space that you mention. I found that I just couldn't seal all the gaps up enough to make it full effictive.
I can take photo's for you if you want but mine is a 9" one. It fits........just.
PostPosted: Tue Jan 20, 2009 6:41 pm
i wired it onto the slats in the guard, doesn't move
PostPosted: Tue Jan 20, 2009 7:08 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
:shock:
https://t.me/pump_upp
PostPosted: Tue Jan 20, 2009 7:21 pm
Milatsmadmini
mine is. and it is great. :D
like Aaron mine is mounted to the radiator directly with sorta these weird zip tie things.... goes pretty good :lol: (this is a moke though and as such not such a big "angle" on the "slats") but its a 9" with 60mm width and yeh.... goes well... :lol:
Users browsing this forum: No registered users and 289 guests
