It is currently Sat Aug 09, 2025 10:33 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: End float
PostPosted: Mon Oct 23, 2006 9:46 pm
Thanks for your input.
Wish I had a metal lathe. Santa comes soon, so who knows!!!
PostPosted: Tue Oct 24, 2006 9:10 am
Anyone put a pulsar dizzy in a positive earth car?
mine is + earth and now i have one, just wondering.....
PostPosted: Sun Nov 19, 2006 7:44 pm
Make it negative earth, it takes me about 10 minutes:
1. turn battery around and reverse battery cables.
2. swap the 2 coil primary wires so that the <->ve one goes to the points and ignition goes to <+>.
Very old coils may be marked CB and B, these correspond to + and -.
3. remove cover from voltage regulator.
using a screwdriver, push the cutout contacts together for a couple of seconds, then pry them apart.
Generator is now polarized for neg earth, go fit your Pulsar dizzy, MP3 player, etc etc. 8)
PostPosted: Sat Mar 03, 2007 1:34 pm
If anyones after any Pulsar Dizzys, yell out, I have a selection of both the 83, and the 85 model.
regards
-Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Tue Oct 02, 2007 9:47 pm
hey does anyone know the serial number or part number for the pulsar dizzy? and also to install the dizzy is there any thing that needs to be done to fit it?
PostPosted: Tue Oct 02, 2007 10:03 pm
hey doc, quick one for you, my old motor had a vacum advance and could notice it when i had a complete seal, pulsar dissy doesn't look like it has a spot to plumb one up, so what happends :?
read the second sticky.... lots of pages, but the detail is all in there.
PostPosted: Tue Oct 02, 2007 10:24 pm
Pulsar dizzy has a vacuum canister, unless you've removed it.
But- if you are talking about a sidedraft Weber or Dellorto carby, NO there is no way to connect it up. Mine runs fine with the canister unconnected.
PostPosted: Wed Oct 10, 2007 10:09 pm
why is there no way to connect a vac advance up with a webber, i have the vacume holes in my manifold, what about a electric advance, even if there is nothing inside the dissy that advances it i was thinking having the whole dissy turn about 3-7 degress with the use of a solinoid,
PostPosted: Sun Mar 30, 2008 1:46 pm
I have New ones of these Vacuum Adv Diaphrams that suit D4R85 Distributors for sale . They are new and will cost you $45 plus post. If you need one email me [email protected]
"Let us remove your "SHORTS"
PostPosted: Sun Mar 30, 2008 2:07 pm
There is no way to run vacuum on a sidedraft Weber or Dellorto because the vacuum levels in each port near the butterfly fluctuate so wildly, unlike an SU. Each port flows for 2 induction strokes then rests while the other port flows.
Anyway- a vacuum advance is just an economy device- at higher throttle openings it does stuff all.
<edit> In a Mini with the usual sporty cam of ~270 deg duration and 106 deg LCA, it does nothing. Due to the valve overlap there is insufficient vacuum to advance it, even at part throttle cruise.
My 45 Dellorto with no vac advance has better throttle response than my twin HS4s with vac advance. 8)
PostPosted: Tue Jan 20, 2009 7:13 pm
Just a quick question about which pulsar dizzy would be best for my set up?
Its just a 1360cc A+, metro head, RE-13, Lightened flywheel, GR 1" 3/4 su Inlet Manifold.
Im goin for a D4R85 but do i need the auto or manual??
PostPosted: Tue Jan 20, 2009 7:29 pm
Doesn't matter which one you use, D4R83 or D4R85- you will need to get the advance curve adjusted to work best in an A series or A+ anyway.
PostPosted: Tue Jan 20, 2009 7:34 pm
Oh ok, yeah that figures i guess.
Thanks
PostPosted: Wed Mar 11, 2009 8:17 am
For those doing this convertion and find they want or need to change the Rotor Button & Dizzy Cap this is what you are looking for
Nissan Pulsar N12 1.5 Motor built from mid to late 80's
Bosch Cap GH617 & Button GH605 should not cost you more than $40 in total
It took me 3 Auto Spare location to get what we need and a bit of internet work :wink:
