It is currently Sun Jul 20, 2025 8:21 pm
 Post subject: Indicator
PostPosted: Thu Feb 17, 2005 5:24 pm
I pulled this indicator assembly off my project and was wondering if anyone knew what model this would have come off. I was told the shell is a 65 deluxe, however it has a floor starter. I found the number 2264 stamped into the bulkhead but no id plate. Any help would really be appreciated.
Dan
http://img.photobucket.com/albums/v517/djhaddo1/DVC01094.jpg
Margaret - 88 Rover
PostPosted: Thu Feb 17, 2005 7:05 pm
Looks like a MK! with a different end. Original was a black plastiic cone with a green lens. Replacement kits can be purchased from Mini Mania - http://www.minimania.com/web/Item/REP01/InvDetail.cfm
David L
PostPosted: Thu Feb 17, 2005 8:39 pm
wow...that's a real odd one!
PostPosted: Fri Feb 18, 2005 6:14 am
I know. Dunno whether it is worth buying the correct one. Saw one on ebay a while back, went for like $160 odd. For that money I'll probably just keep this one.
Margaret - 88 Rover
 Post subject: blinker
PostPosted: Fri Feb 18, 2005 10:55 am
It looks like a broken then modified MKI bliker assembly
They are available new from UK about $105 plus shipping.
Steve
PostPosted: Fri Feb 18, 2005 2:02 pm
I have never seen one like that before.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Fri Feb 18, 2005 2:36 pm
I'm referbing a MKI now and will be listing it on eBay at the weekend - $75 starting price
David L
 Post subject: Re: Indicator
PostPosted: Fri Feb 18, 2005 5:08 pm
Dan]
if it has a floor starter and windup windows, check the floor where the gearshift hole is. If it has a hole for a remote gearchange next to the floor starter, it is probably hacked, and there should be a proper one at the front of the footwell that may be covered. Confused yet :? If all of the above is true, you may have a Morris Mini Minor shell, produced 1965, 66. They were a "povo pack" for government agencies that only had an 850cc engine and the bare minimum of trim. It may also have the pressed aluminium grill, rather than the slats of the deluxe and cooper s. Mine is apparently a 1966 model, and the body number is 1079, so the sequence looks a bit funny if yours is one of those.
michael
PostPosted: Fri Feb 18, 2005 9:41 pm
We have a winner!!! :D
mickmini you are absolutely on the money. The remote hole has been cut and the one in the footwell bogged up.
Things I should have known before buying another shell. :roll: Wouldn't have made a bit of difference though. Can't pass a bargin up... :lol:
Margaret - 88 Rover
Users browsing this forum: Dan69s, Scoop and 68 guests
