aaron wrote:
Which bring me to the next question i have been going over. Compression, what are looking at as Std bolt on. I know david has found the compression ratio was way too high and has added a plate to suit. I would think that this would also be helping alleviate the Piston/valve clearence issues. Is this something that the other head conversions are going to need, or will they need cutout pistons.... Again, how much is that going to set us back?
Aaron
It`s quite interesting that you use the words "Std bolt on"-----i don`t know of many "Std Bolt on" cyl head conversions,,, the KAD heads, the Jack Knight heads, Elder heads & Arden heads would have to be the closest to "Std bolt on" than any of the others, but still they all need some forms of modification to fit them "Correctly" & have them running well,,, & all are very expensive propersitions... there is no "Cheap, bolt on" wonderful amazing cyl head conversions avaliable,,, they all need some form of mods & all need more money than a std 5 port engine to build.
The Bimmer 8V cyl head has a combustion chamber capacity of approx 21.5cc,,, so is well suited for fitting to a mini block with just fly cuts needing to be machined into the tops of the pistons,,,
the 16v head has approx 28ccs in it`s chambers so makes for a slightly lower compression with std-ish pistons, however it`s easy to just use flat tops & have the fly cuts machined into them & deck the block to the desired height to suit whichever applcation (high or low compression),,,, that`s your choice -->no matter whatever engine you decide to build.
it`s also interesting that you use the term-->"Serious Pistons" ... but they`re not needed at all , unless you`re thinking of going full race or high boost turbo application,,, but that rings true with any engine tho, be it twin cam, 8 port or 5 port, so it`s not really an issue at all & is std engine building practice to have all this worked out on any engine before it`s built to make sure you don`t have too high, or too low compression to suit your application, & or any part of the piston hitting any valves,,, it`s quite normal for the engine builder to sort all this stuff at the first "DUMMY" up of "ANY" engine,,, again it`s all std engine building practice no matter what engine you`re building.
the fly cuts into the tops of the pistons cost appox $150 to do, depending on who does it for you if you can`t do them by yourself..
What is also interesting is that there are very very many web sites that list most (if not all) the mods needed to suit all their various forms of mods needed to fit each of their own cyl head conversions
there are also build guides avaliable for most of those too, which explain in great detail most of these conversions
Davids conversion s still in it`s infancy & what a wonderful thing he`s doing i might add,,, allowing all the world to see what he has achieved so far via the net is truely wonderful & his time is most valuable & his information is spreading over the net,,, as is another fellas own conversion using a fiat punto single cam 12v turbo charged with LPG , just yet another example of what any one can do with a little thought & a little home work
MY R1 yamaha 20v cyl head (if/when it comes to fruit) i hope to be yet another example,,,
but some of these conversions just don`t quite have perfect accurate detailed info avaliable at this stage of their development, not many people will happilly devulge all their info either.
I think it`s just wonderful how much info is actually shared tho, all around the world, via the internet ,,,,& how easy it is to click on & find it all....
Don`t you?
It`s just amazing how easy it is these days,,, back when i was a kid we didn`t have any of this avaliable to us & we had to do all our homework by our selves & sort all our curiosities by both theoretical & physical trial & error:-) physically running all over the place to all sorts of car & bike wreckers measuring & facing up & buying all sorts of things , just to see if we have something close to fit.
an example here would be the old 4 cyl motor bikes used to have a centre designed cam chain assy , (fitted in between number 2 & 3 cyls) so it made it very difficult to adapt one of those old design bike heads to a mini donk,,, but as soon as the end mounted cam chains appeared in the 80s(ish) there was a golden opportunity for some "Play time"
Not many people realised it back then but there were a few who did & took advantage of that,,, but it`s taken years of playing & many many hours wasted sorting all the possibilities,,, yet here we are finding even more & more cyl head conversions avaliable to us... because some lovely people have spent their valuable time & money soring it all for us
i think it`s just a dam good all over wonderful feeling
Don`t you?
