It is currently Fri Jul 25, 2025 8:46 pm
 Post subject: Fibreglass Flipfronts
PostPosted: Sat Feb 07, 2009 12:39 pm
Die Die Die!!
does anyone know somewhere that sells fibreglass nose shells
PostPosted: Sat Feb 07, 2009 12:40 pm
Brickworx has some.
:D
PostPosted: Sat Feb 07, 2009 12:48 pm
Die Die Die!!
those are clubman ones.. perhaps i should have been more specific, does anyone know somewhere (in australia) that sells extended (90mm) Fibreglass Roundnose front peices...
PostPosted: Sat Feb 07, 2009 12:51 pm
i doubt anyone sells the extended ones... you building a vtech?
Potato
Just get a clubby one!
I'm positive Steve has a roundy one there. Okay, so it has a big ugly scoop on it but its fibreglass, so easily modified.
:D
PostPosted: Sat Feb 07, 2009 12:52 pm
Die Die Die!!
haha, someones on the ball ;)..
Die Die Die!!
:D
yeah well i dont wanna hanve to frig about modifying.. id preffer to import one from the US before i stuff around doing that.. plus i dont really have anywhere to do it as i live in a flat
PostPosted: Sat Feb 07, 2009 12:57 pm
i believe the vtech subframes are different to over here for some reason that im not sure of.. so be careful that they arent different when ordering one
Potato
PostPosted: Sat Feb 07, 2009 1:07 pm
If you don;t have the room to modify a fiberglass flip front. How do plan to achieve the conversion. I'm not having a go, just a serious question. Are you having someone do it for you?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Feb 07, 2009 2:11 pm
Die Die Die!!
Ryan
thats a good point.. ill take it a friends or relatives, but id preffer it all be fairly bolt-on the more work i can avoid having to do the better, (obviously there will be some work)
PostPosted: Sat Feb 07, 2009 2:19 pm
Well if you are going to buy a Minitec frame and driveshafts etc etc. I wouldn't think it'd be too much more bother to order a front with it too.
PostPosted: Sat Feb 07, 2009 2:21 pm
Die Die Die!!
well i thought that... but i thought id see if there was anything local..
PostPosted: Sat Feb 07, 2009 2:48 pm
Yeah I get ya, but extended fibreglass fronts here are very rare.
Most people here would just use a Clubman. Even then room is hardpressed. I've got a big front spoiler/body kit for mine to make sure the intercooler isn't hanging out the front!
But I understand that you want a roundnose front, fair enough have fun!
PostPosted: Sat Feb 07, 2009 3:03 pm
are these kits legally fittable over here for a road car??
Potato
PostPosted: Sat Feb 07, 2009 3:10 pm
From looking at it, not really. But where there is a will there's a way. Needs more engineering approval I guess. They look like they extend the track of the car up front a fair bit, so I don't know. They also change the suspension setup which will require engineering as well. The less you change the less work needs to be done I think.
<edit> To me though the road worthiness of it is not that big a deal. For my car it should be a road car but if it all gets too complicated, I'll finish it as a race car. Would be fun for hillclimbs I reckon.
Users browsing this forum: Bing [Bot] and 99 guests
