My Mini was a Matic, fitting a motor with remote box is easy.
Cover the original shift cable hole, cut a new hole for the shifter, get the tunnel mounting bracket for the remote and drill 3 holes in the tunnel for it. Oh, and better fit a clutch pedal and master cylinder.
Note you cannot fit a manual box to an automatic block without modifying oilways in the block. Unless it's a 1275 it's not worth the trouble.
If it is, see my auto block thread in the how-to forum.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
