OK almost 24 hours later and i have
New battery 440 CCA.
New coil, leads and condenser
i cleaned the earth strap for the engine
checked the dizzy and rotor button contacts, all clean, carbon contact is good
points are clean and correctly gapped
spark plugs are clean and correctly gapped
i checked that i have the leads to the right cylinders, anti clockwise ...yadah yadah
i filled the float bowl with fuel. i have cranked it enough that i see fuel in the filter.
the carby is the same one that i had on the engine when it was in the other car on a standard 1.25 in inlet manifold cut off from the exhaust. I did have headers and big exhaust on the engine in the other car. so the only difference is the exhaust is now cast standard manifold and peashooter pipe.
What am i missing? it was all running in the other car before i pulled it out
it cranks over fine, and i get a reasonable spark, not pulsar dizzy standard. fuel is going in because every now and then it backfires up the carby as i crank it. i played with the dizzy timing to see what difference it would make and nothing. it just does not want to kick on. so much for taking it to the drive in tonight. anyone got a spare mini needs a driver and are in between inner west and blacktown?
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
