It is currently Thu Aug 14, 2025 5:59 am
PostPosted: Mon Feb 16, 2009 6:46 pm
hi.. possible stupid question
just about to install a thermostat in the mini (was an empty hole before)...
anyway while reading the numbers on the new thermostat I noticed it had 96C on it.. does that mean it opens at 96C?!! Because I bought it as an 82C one...
it's a columbus, part number (on the box) AS240180, and on the thermostat itself is stamped WTI 96C J6 180..
thanks,
Tim.
tim
PostPosted: Mon Feb 16, 2009 6:51 pm
The important bit is the 180.
180°F = 82°C :wink:
PostPosted: Mon Feb 16, 2009 6:55 pm
bah!
almost dark.. hopefully get this all back together tonight! thanks. so much!
tim
PostPosted: Mon Feb 16, 2009 7:30 pm
And the number that its rated at means thats when its fully open yes? or is it when it starts to open?
PostPosted: Mon Feb 16, 2009 8:30 pm
another question.. this time about bottom hoses...
the hose I got is the type for 1275 with heater. the main problem is that it seems to rub at the rear, against the firewall/brace.. do these hoses usually require a bit of trimming at the ends? I figure if I take 5mm off the top end of it it will bring it forward a little.
tim
PostPosted: Mon Feb 16, 2009 9:18 pm
Yep if too long just trim a bit off.
When they made em here, they were the right length... :roll:
Users browsing this forum: No registered users and 280 guests
